shroud for Summit/Jegs aluminum radiators - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-07-2008, 07:32 AM
Hi everyone - I'm using the 28x19 radiator in my 67 Dart with a flex fan (no room to use a clutch fan at this point). I'd like to add a shroud to it, and would like to hear if anyone knows of a good one that can either be found at a junkyard, or bought somewhere. The surface is about 22 w x 19 x for a shroud.
Summit sells a universal shroud, but it looks like weld on, and I have heard on a Mopar site that someome has used a mid 70's Dart shroud, cut down a bit. Since mid 70's darts are rare to see in junkyards around here, I was hoping to hear if someone else has located a good junkyard shroud donor for these radiators.
Thanks.
Pro Topline Heads surfinca Engine 33 12-28-2008 11:37 AM
Aluminum Rad or Home made fan shroud? sandiegopaul Engine 18 06-14-2005 02:10 PM
Jegs aluminum radiators???? 1quiknova Engine 4 05-10-2005 04:11 PM
Prepping aluminum BarryK Body - Exterior 3 06-13-2004 08:07 PM
Aluminum radiators zonk General Rodding Tech 5 11-14-2003 05:25 PM
