Shut off problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2008, 02:55 PM
Shut off problem
all my hotrods are running right now.. but i do have a 1988 Mazda 626 2.2l full injection car (no cracks about imports) it cranks up idles in park idles and runs in reverse, idles in neutral but as soon as u put it into drive it shuts off. Any information on what may be causing this to do this would help.. cause this car would save gas and that means more money for me to spend on hotrod parts.
Old 08-07-2008, 08:43 PM
Holder350's Avatar
Auto Parts Professional
does it "bog" down and shut off or does it seem to lose fire?
Old 08-08-2008, 07:18 PM
It just shuts off.
Old 08-08-2008, 08:43 PM
Holder350's Avatar
that is a new one on me.....will it move in reverse?
Old 08-08-2008, 09:07 PM
justacertifiedtech's Avatar
or was that certifiable?
Last wiki edit: How to find an electrical drain Last photo:
Wiki Edits: 3
OK, Follow your air inlet tube (flexible tube about 3" in diameter) between your airflow meter (mounted to the box your air filter is in) move and flex this tube while the engine is running if the engine dies or stumbles real bad the tube has cracked and/or split (usually between the flex joints). I have seen many vehicles with this type of system do the exact same thing. As you put it into drive the engine torques to the back stretching the tube and opening the crack/split. this allows unmetered air in which will confuse the computer and kill the engine.
Check that and let us know what you find. If this is your issue you can use some good duct tape to temporarily seal it but you need to go ahead and get a new one because it will split somewhere else again.
Old 08-09-2008, 08:42 AM
Yes in reverse it drives great.
Just found it!! the air intake hose had a big hole in it that u couldn see unless u pulled on it or squished it! thx guys. I'm going go get a new one and hope it fixes the problem That was the problem exacly
help troubleshooting 89 350 TBI problem? Chuck78 Engine 14 09-15-2013 06:32 AM
I'm having a primer adhesion problem on one door Ripped Body - Exterior 10 06-08-2007 12:45 PM
96 Plymouth Voyager spark problem? baddbob Electrical 12 05-19-2007 03:44 PM
Puzzling temperature problem on the hemi solved Centerline Engine 2 11-26-2004 03:48 PM
Puzzling overheating problem on the Hemi Centerline Engine 30 11-23-2004 06:33 AM
