Originally Posted by tlc568
I have a 1990 suburban, after about 10 minutes running it shuts down. the service engine light is on.
I have replaced everything in the ignition system includeing the ecm.
i have replaced everything in the fuel system except the tank. this includes the fuel pump relay.
afer running about 10 minutes it shuts down and wont restart, no fire.
then after about 3-4 hours it will start only to run 10 minutes and shut down.
help frazzeled
What are the stored codes? That's where to start.
If you have verified there's no spark, I'd suspect a faulty module- but instead of throwing part$ at it, diagnose it first, then replace only what's actually needed.
