Sick SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-27-2006, 08:20 PM
Sick SBC
Ok guys since I have found great help here in the past here we go again. Just another issue with my sons SBC. Here are the details
SBC stock bottom end
Dart Iron Eage S/S heads with a 2.02/1.60 valve job
Erson cam (mild) .429/.449, erson timing set, lifters
Erson Roller rockers
Z 28 springs
Performer intake
600 CFM Edlebrock performer series carb
MSD HEI distributor
Headers
Issue is this....has been running great until about last week.
It has developed a rough idle and while driving below 1500 RPM feels like engine is missing and stumbling...above 2000 runs pretty well....wants to stall at low RPM...holding throttle open in driveway at about 1200-1500 you can hear popping in the exhaust sounds like it is dropping a cylinder and if you blip the throttle you can get it to backfire through the carb...
Have checked the following.
1. Checked timing...all in at about 3200 RPM total 30 degrees
2. New plug wires....Taylor Vertex
3. New plugs....
4. New cap and rotor
5. Complete rebuild on carb
6. Checked vacum and is pulling about 16 in at idle....slight needle movement....less than 1/2 in just wobbles a little.
7. Checked for vacum leaks....found no issues there
Any guesses???.....have not pulled the valve covers....this is next on the list.
Thanks for your help!!
Old 03-27-2006, 08:51 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
Could have a wiped cam lobe. Need to pull the covers and take a look at the valve movement. Fuel PSI ok??. Ignition module and or pick up coil could be failing! Spark strong enough?
Old 03-27-2006, 09:07 PM
MI2600's Avatar
Member# 3287
I also would have to go with a cam lobe/lifter/rocker problem.
Old 03-27-2006, 10:31 PM
eight90's Avatar
I also agree with a cam or valve spring problem,,,,,, first of all 30 degs of total timing sounds a bit low to me. Give it more total timing,, 36-38 degs and see what happens.
Old 03-27-2006, 10:38 PM
sbchevfreak's Avatar
Licenced Automotive Technician
If they're not screw in studs, could have pulled a rocker stud. 67 Duece could also have hit it with the P/U coil.
Old 03-28-2006, 03:22 AM
57 Chevy's Avatar
Daryl
Location: Montana, now Arizona.Now Colorado. Wish I was back in Montana
just my 2 cents, but I'm thinking like the others above on the cam issue. When he first fired it up, did he take it up to 2000/2200 RPM for about 20 minutes to break in the cam? Engine speeds below that don't spray enough oil to lube the cam and seat the lifters to the cam.
Old 03-28-2006, 07:08 AM
Thanks!
Thanks guys for all of the response.
I did a little more checking last night after I posted and noticed that while I had the timing light out that when I pulled the vacum line to the vacum advance canister on and off the unported side of the carb that I saw no difference in the timing???...I would have assumed that I would have seen some?....correct or not???....
The "old man" ran out of gas last night before I could start on the valve train so that is on tap this afternoon.
The cam was broken in properly when installed and has performed flawlessly over the past 5000 or so miles.
I do have a brand new module laying in the garage that I thought I would swap in this evening to see if that helped.
Why I have grown to hate the Small Block Chevy..... an essay Centerline Hotrodders' Lounge 316 02-08-2012 10:46 PM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Why not a 350 sbc? bowtieorbust Engine 29 09-05-2008 09:43 AM
Sick to death of SBC kc_ksom Engine 9 01-11-2006 06:11 AM
Late model 350 SBC Question Smoker113 Engine 3 02-19-2005 10:12 PM
