Which side of the cross-member? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2006, 09:46 AM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Hi Fellas,
I'm having an "CRAFT" moment ... (Can't Remember A Fricken Thing)
I robbed this cross-member and brace from a 1976 C10 ... and I *think* that the brace in the picture goes on the driver's (torque) side of the trans.
(Larger, more detailed version of this pic is in my journal.)
Of course I sand-blasted and painted it ... so any "marks" ar long gone.
Can anyone confirm or deny my theory? Or does it matter?
Don
Old 09-12-2006, 06:06 PM
tnsmith10's Avatar
when will it rain???
for that particular x-member, theres usually 1 on each side. now if it has the upward bend that goes up the drivers side frame rail, then that bracket would go on the passenger side... gl
Old 09-12-2006, 09:46 PM
66GMC's Avatar
I think you're right.
This cross-member doesn't have the (non-detachable) bent part, but the one from the 79 C20 donor truck did.
Looking back thru my journal, it looks like I had "test-fit" it using the detachable bracket to the right.
Maybe I'll make another trip to the boneyard and see if I can score another bracket ... then put one on each side.
I guess that certainly wouldn't hurt anything, and may even help to stiffen that frame. I'm expecting quite a bit of torque from that 454.
Old 09-12-2006, 09:56 PM
powerrodsmike's Avatar
Wiki Edits: 161
I think tnsmith is right, I know my blazer has the extra bracket on both sides and my sister in laws 70 c10 does also.
later, mikey
BE different....ACT normal.
Old 09-12-2006, 10:09 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Sweet project Are you going to run an overdrive transmission with that big block?
Ditto
Old 09-13-2006, 09:05 AM
66GMC's Avatar
Ditto
Thanks... it's slowly coming together. I think it's gotta go on hold for a bit, while I build my OWN garage. I'm tired of imposing on friends for storage space, and it limits my "tinker" time.
I've just overhauled the TH400 from the donor vehicle, and bought a new B&M Nitrous Holeshot 2400 stall convertor to go with it.
I don't know if this truck will ever see a lot of highway time or not. Actually it might ... if I get into the "show & shine" circuit, it might travel within 100 km's (65 miles) to neighboring towns.
The closest drag strip at the south end of Calgary ... also 90 or more km's ... and I think I'd like to run it there occasionally.
Lastly, I'm not a fan of 700-R4's. I know that they can be "built" to take it, but at what cost? Perhaps sticking with the TH400 and adding a Gear Vendors OD would be a better choice. I guess I'll cross that bridge when I come to it. Right now, I just want to get it together and fire that puppy up!
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 08:33 AM
68 vette rear cross member stuck fire power Suspension - Brakes - Steering 0 02-14-2006 07:20 PM
Meaning of the iron cross? FASTCHEVY Hotrodders' Lounge 15 03-05-2004 11:01 PM
mustang 11 cross member 38harry Suspension - Brakes - Steering 0 01-28-2004 12:47 PM
Hot exhaust on one side of dual JUSTINH Engine 18 08-29-2003 03:12 PM
