Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 08-24-2005, 01:42 PM
85CHEVY's Avatar
85CHEVY 85CHEVY is offline
side exhuast exits or rear exits?
I am going to put a 2.5 inch dual exhuast on my 84 GMC 350/350. It will be connected to hedman 1 5/8 headers with 3 inch collectors. Will I lose any performance by just routing the exhuast out sides in front of the rear wheels?
Old 08-24-2005, 01:51 PM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Yup One of those Moderator's
 OneMoreTime's barnstar
Wiki Edits: 3
re: side exhuast exits or rear exits?
Nope..looks more "finished" to route them out the back tho..
OMT
If it don't work it ain't pretty!!!!
Old 08-24-2005, 02:34 PM
82c10 82c10 is offline
do you have pics of your headers, i am thinking about getting some of those because my current ones sits way to close to the starter, and positive battery cable,as for the question, i think it will not hurt it any, it might even help it, i also know a website you might like, it is www.67-72chevytrucks.com it is for fullsize chevy's and gmc's from 47-98, i think you will like it
Old 08-24-2005, 02:36 PM
Canzus's Avatar
Canzus Canzus is offline
If you don't mind cleaning your wheels every
other day, go for it, but IMNSHFO, I'd rather see
them sticking out the back. If you're worried about
the Piping losses, run bigger pipes...
Old 08-24-2005, 03:14 PM
i have not seen a vehicle that runs right make the wheels that dirty
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "side exhuast exits or rear exits?"
Rear end swap required & I'm cunfussed datsun dale Transmission - Rearend 6 01-09-2006 10:10 AM
Side pipes or rear nd500 Engine 1 04-03-2003 05:46 PM
anyone running 700r4 with 3.55or 3.77 rear end? 37 chevy Transmission - Rearend 7 01-06-2003 05:34 AM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 09:50 PM
Rear end Buffed Engine 3 10-31-2002 04:11 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
