Side exist exhausts advantages? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2006, 12:32 AM
What would be the advantages of side exit exhausts?
......and disadvantages?
Old 12-02-2006, 05:06 AM
The point of exit of an exhaust system will have little to do with performance but may change the sound. The physical size and configuration will have much more effect.
Old 12-02-2006, 07:23 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
on the right car they are just KILLER cool, another reason for side exhaust would be to get the heat out from under the body ........... I love em and think hotrods and vetts should have them as a standard........... AH but that is just me
Old 12-02-2006, 06:13 PM
I have the Sanderson Jaysters on my '32. The look good and sound nice....but....after 30 minutes they will drive you crazy by the noise and the gas smell will give you a headache.
I'm switching them to rear exiting exhausts with electric cut outs...
Old 12-04-2006, 06:49 PM
look great. sound great, and easy install
Loudand not always legal.
But I say do it.
[IMG][/IMG]
Old 12-05-2006, 08:12 PM
strummin67's Avatar
Violating consensual reality
Last journal entry: It tows!
Disadvantages: Louder, burn your ankles getting in
Advantages: Looks way cool on the right cars and I'm told it helps prevent fumes from getting in while driving a wagon with the rear window down. However, that isn't the case with mine.
Strummin
Old 12-05-2006, 08:22 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Advantage - look great and you don't have to route exhaust under car where space may be limited.
Disadvatages - burn legs, burn legs, burn legs! At least two times every time I go somewhere with my brother in law.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Name:	collectors 6-7-06 001.jpg
Old 12-06-2006, 01:16 AM
Guys, thank you to you, all.
But no thanks to side exhausts........though I like strong torque, I like smooth, and quiet torque, and I like my air fresh, and clean.
Old 12-06-2006, 06:38 AM
pepi's Avatar
if one keeps burning legs, which I personally have NEVER done, I think the problem is the person not the side exhaust ........... hint! do not put your legs on the pipes or maybe your legs are just to short, whatever the reason it is not the pipes fault just in case you were wondering.
Old 12-06-2006, 08:13 AM
Another shortcoming of most side mount exhaust systems is that they will remove a significant amount of power from the drivetrain. A friend of mine dyno tested a mid-year Vette with Hooker side mount headers and gained almost 100 hp by switching to an underchassis setup.
Old 12-06-2006, 10:45 AM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
I like the Challenger T/A sidepipes look; just exits on the side, not the whole dang pipe.
Old 12-06-2006, 10:47 AM
home brew's Avatar
Four inch chop, four inch channel, twist like a prezet to get in, twist like a pretzel to get out, watch that you don't bang your head, forget to watch where your legs are going when you get out, burn legs. I will be using a side exhaust on my Nashty and will put up with a few more leg burns because they look so great!!!
Old 12-10-2006, 09:11 PM
FordMan1951's Avatar
Ford Man to the bone!!!
HUH???
Which way the exhaust left the car made THAT much difference? Could have been a better tube length match-up in the under-car set? Still, I bet the side exhaust looked really cool. Now if he could just find a set of pipes with true equal length and side exit.
Old 12-10-2006, 09:21 PM
User
There is a primered Chevette around here, with a single pipe coming out of the lower front fender, curves up, and is actually higher than the roof of the car.
I dunno what kind of driving their doing...
left side brakes wont work racur96 Suspension - Brakes - Steering 1 07-22-2006 03:32 PM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
distributor moving from side to side pcoghlan Engine 16 05-31-2006 11:17 PM
Postive ground but negative coil, strange one Nightfire Electrical 21 04-19-2006 05:20 PM
Side pipes or rear nd500 Engine 1 04-03-2003 06:46 PM
