side mirrors - need to make rubber gasket/grommets - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2005, 02:34 AM
Socket Breaker
Last journal entry: My website for my '65 chevy c10 lwb step
Hiya folks.
I have these mirrors here:
The painted white ones on the right side(the shiny ones are fomoco)... for my '65 chevy truck.
So, I want to mount up my side mirrors, but I bought these mirrors used, as they are '64-'66 vintage OEM chevy parts... so no rubber gaskets to fit between the mounting arms and the body of the door.
I am looking basically for a printer paper sized sheet of rubber to cut my own gaskets(for lack of a better term). When I was a kid this was a common thing... I found the cork and paper(for using with fuel systems) gaskets, but so far no joy on the rubber.
I went around to some parts stores today and the parts people looked at me and said: yeah, that seems like something you could get in a parts store, but I don't know of anything we have.
I'm thinking maybe they have it, or they can get it, they just do not know exactly what to call it.
So, if anyone has any information they can share.. parts numbers, names of brands, name of product, whatever, I'd appreciate it.
I'm also going to try the local hardware store, we have a pretty good one, maybe they have something I can use.
Thanks,
-W
Old 11-05-2005, 03:38 AM
milo's Avatar
point on positive
Bicycle inner tube...
Longs...
$ 3
Old 11-05-2005, 06:28 AM
we've got an 84 ford 1 ton we use around the farm....last year we pick'd up some of those mirrors and ran into the same problem
hubby went to wal-mart, bought the cheapest black floor mats he could find, traced the mirror base, whittled them out with an exacto knife and job well done
Old 11-05-2005, 07:45 AM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Most auto part stores should have small roll's or sheet gasket material that you make your own with.
I've used inertube before but it's really too soft and squish's out the edge's.
Go to the houseware's section and look for some place mats for the dinner table. Or the Art & Craft area. You'll be amazed at what all you can find there.
Especally BABE'S!!
Old 11-06-2005, 09:07 PM
Socket Breaker
Thanks to everyone for the ideas.
Bee4me,
I went to the parts store, the local Advance were too busy bickering with each other and the local NAPA guys looked at me and said: yeah, you'd think you could get something like that at a parts store...
I found the cork roll sheets, like you would use for valve cover gaskets and the thinner paper type roll sheets for fuel system uses, but no rubber ones.
I'll try again and check out some of the ideas I've read here and in other places.
Thanks again,
-W
Old 11-07-2005, 05:40 AM
Rubber will probably be too soft and will squish. Use some black plastic. Lawn edging, place matts, coffee can lids, various containers, auto parts-splash shields. Use some good sealer on the fasteners and also under the gasket.
Old 11-07-2005, 09:54 AM
Go to the hardware store (Ace, Lowe's, etc.) and look for their rubber gasket material sold in bulk rolls. It's available in several thicknesses, so one should be what you're looking for.
Old 11-07-2005, 07:50 PM
New Member
And that's the exact reason you should use rubber, not plastic. It creates a seal between the object, in this case a mirror base and the body of the vehicle, preventing water from getting underneath, which potentially causes rust on the body and the mounting screws.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
"Basics of Basics" Sectioning a Body MARTINSR Body - Exterior 7 11-24-2008 12:04 PM
one side is1.75" lower than the other side. brian400ex Suspension - Brakes - Steering 15 04-01-2004 04:34 PM
Removing fenders? Jag Daddy Body - Exterior 3 11-26-2003 04:42 AM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
