Side View Mirrors: Suggestions for '54 Chevy Pickup - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-25-2010, 08:57 PM
AntnyL's Avatar
Originally Posted by horvath
Thanks, Dan.
AntnyL: I had repops ... didn't like the look. Mine's a street rod ... but my main reason against the repops is the poor quality; I mean it couldn't get much poorer! The swivel joint rusts out BIG time and, of course, the chrome is garbage.
Whatever mirrors Harley makes is gonna be top-shelf quality, I'm sure of that.
Gotcha, Horvath. Nuthin worse than crappy repops! Post up some pics when you get the HD mirrors mounted.
  #17 (permalink)
Old 12-25-2010, 09:49 PM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
Will do.
:o)
  #18 (permalink)
Old 01-04-2011, 05:27 PM
horvath's Avatar
Originally Posted by NEW INTERIORS
Hey Alan !!!! Man I haven't seen you and a while.. Great to see your still around,, I have used the motor cycle mirror's, They make all kind of cool ones, The only down side is they are smaller.. But they are cool..
I'm wondering about the mounts on motorcycle mirrors ... do they hold firm? Or do they wobble!!??
Fill me in on your experience.
Thanks.
Alan
  #19 (permalink)
Old 01-04-2011, 05:35 PM
NEW INTERIORS's Avatar
Set no limit's on yourself
Thanks.
Alan
Alan.. I had the MALTESE CROSS MIRRORS and one bolt on that rat truck I built.. I didn't have it long enough to say.. But I really was satisfied with them.. I really think they would have been fine..And would use custom motor cycle mirrors again.. The down side was you can't see to good with them.. But it made it legal, And looked very cool..
These are the ones I had..
http://cgi.ebay.com/ebaymotors/ws/eB...31760601198206
  #20 (permalink)
Old 01-04-2011, 07:40 PM
horvath's Avatar
I can see how they wouldn't give you much in the way of viewing, but they really *are* cool looking!
If they mount securely and hold firm, I like the idea of some of the Harley Davidson mirrors ... but they are designed to mount through a hole on the brake/clutch handles and it looks like they aren't threaded all the way. Don't you need to apply some kind of a bushing to make up for the lack of thickness when mounting on a truck/car body?
Alan
  #21 (permalink)
Old 01-04-2011, 10:46 PM
The ones I used, Was threaded.. I mounted them on the top of my door frame.. The door frame was 1''x 2'' tubing.. I drilled a hole through the tubing and ran the bolt from the inside.. You can put any length bolt you need to.. On the ones I used.. Some are different...
  #22 (permalink)
Old 01-05-2011, 05:38 AM
Underground's Avatar
Last journal entry: 54
You can also look in a street rod mag like Street Rodder. Hundreds more to choose from and they are usually mounted like regular car mirrors. You also can put a dab of thread lock on them and they don't loosen up.
  #23 (permalink)
Old 01-05-2011, 07:29 AM
horvath's Avatar
Thanks for your help, guys. I'll be posting pics on what I wind up installing.
Alan
  #24 (permalink)
Old 01-05-2011, 09:34 AM
cyclopsblown34's Avatar
Colorsanding painter
Originally Posted by Irelands child
I used the round brushed aluminum Sun Spec Billet Factory mirrors on my '31. They satisfy the "law", work just fine, plus are small enough that they are barely noticed. Not cheap, I found out: http://www.ssbilletfactory.com/
Rich (Sun Specs) is only about a half hour from me. He turns out some killer stuff.
  #25 (permalink)
Old 01-05-2011, 10:47 AM
You can always make a piece (Billet) that you can Tig to the end of the arm, Then install two studs and then it won't move.. Just Tig it on, Polish it up, Bolt it on.. then go..Look cool and won't move..
  #26 (permalink)
Old 01-05-2011, 11:00 AM
horvath's Avatar
Now yer tawkin'!
:o)
That would make it happen for sure. Thanks, man.
Alan
  #27 (permalink)
Old 01-05-2011, 11:02 AM
Now yer tawkin'!
:o)
Alan
Anytime Alan... Just letting my mind go crazy again.. I do that sometimes..
  #28 (permalink)
Old 01-05-2011, 11:36 AM
dinger's Avatar
I love the look of the mirrors on my coupe, but I can't see diddly out of them. Now if I could steal Alan's idea of the cameras, mount them somewhere where they don't take away from the old look, pop the screen out with some Velcro, I'd be set. Alan, keep us posted on the cameras, please? I was cruising up 99 the other day, had to make a quicky lane change that didn't happen real quickly, made me quite nervous. Thankfully, no cars were close by. Dan
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
  #29 (permalink)
Old 01-05-2011, 01:30 PM
DanTwoLakes's Avatar
Wiki Edits: 22
If you're looking for great quality, look at the peep mirrors from LeBarron Bonney. Look at their part number CNX-18414-LR. This is a pair of peep mirrors at $72.50 per pair. Here's the link:PEEPS
  #30 (permalink)
Old 01-05-2011, 02:55 PM
horvath's Avatar
Hey, Dan
Here's where I'm at so far:
Cameras Mounted On the License Plate Frame
Cameras You Can Install Yourself
And Here's A Monitor
Also, CarToys.com has more options.
1969 nova side view mirrors 69novaguyela Body - Exterior 1 05-05-2009 03:07 AM
cameras for side view mirrors? americanLT1 Body - Exterior 3 09-06-2007 01:45 PM
Heated rear view mirrors Ripped Electrical 1 01-12-2007 01:53 PM
side mirrors - need to make rubber gasket/grommets Woogeroo Body - Exterior 7 11-07-2005 07:50 PM
