Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - siezed oil pump
Thread: siezed oil pump
Old 07-17-2008, 12:44 PM
nosman nosman is offline
siezed oil pump
Iam having oil pump problems I have siezed two HV meiling pumps motor is new built 351 windsor alum heads fox body oil pan all MSD setup frist pump took the oil pump shaft this one took the gear off the distributor has 50-60 psi thru out rpm range any help would be great. Thanks
