Siezed up rebuilt cleavland - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-02-2013, 12:41 AM
I put a rebiult 351c in my mach1,,after the install it sat for a few months over the winter. I finally got time and put it together..got the battery in..turned the key..click,,click,,nothin. Anyhow i put a socket on the front of the crank,,and it wont budge. The moter was never run..but turned over fine when i put it in..{bolting flywheel to torque converter}\ I spent big bucks on this moter..now i just want to sit in the corner of garage with a 40 0z and cry,,,I removed plugs and sprayed in realese-all and wd40...not sure what else to do..could use some advice...thanks.
Old 04-02-2013, 01:57 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Have you tried to rotate it by hand at the flywheel to make sure it's not the starter or electrical? Unbolt the converter and try it. Using the crank bolt isn't recommended.
Semper Fi
Old 04-02-2013, 07:42 AM
Richiehd's Avatar
JS-70
Im with 68Nova. Im thinking you have something going on in Flywheel/tranny section. Maybe flywheel bolts or something.
Old 04-02-2013, 07:47 AM
One way to move it ever so "slightly" is to put a pry bar between the ring gear and block, and "pry" it about one "tooth". If it moves without massive resistance, you should be okay. Remove all the spark plugs, re-prime the oil system and try the starter again. If it resists, then "pops" free, you have fretting corrosion from the rings to the walls. It will have to come out, be re-honed and new rings.
Best of luck.
Jim
Old 04-02-2013, 08:43 AM
THanks
Ya im gonna remove starter, when i first hit the key it sounded like it jammed..then loosen flywheel if that dont work. It's been in garage the whole time so it has me cunfused. I will post later today of my progress. THanks
Old 04-02-2013, 03:45 PM
Oppsy daisy*
WEll boys i got er now...This is embar-assing to say the least. I crawled under the car to inspect the flywheel..low and behold..the torque converter wasnt even bolted up..the bolts welded to the converter were half way in between the flywheel..no where even close to the holes..so they bound up against it..i cracked the tranny loose..spun the torque..lined up holes..and actully put nuts on em this time..wala!! turned key..motor spins out like the wife on a friday night..awsome help guys..checkin the flywheel really panned out for me. I thought i had done that..but i guess when i was bolting moter up i should have left the budwieser in the fridge...thanks again.
Old 04-02-2013, 05:34 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Great! I would still prime the oil system before firing it. If for some reason you can't, watch for pressure the minute is starts, but keep in mind it will still be considered a dry start.
Semper Fi
Old 04-02-2013, 08:31 PM
It might not hurt to place a little engine oil in the cylinders before you put the plugs in and turn the engine over by hand after you've oil primed the system as that way there will be better lubrication on the cylinder walls as soon as the engine fires. Not to say that it will be an issue but penetrating oils are very thin and wouldn't be as good as a nice thin coating of engine oil on the cylinders. Then leave the engine sit for a bit to allow the excess oil to slip by the rings before you try firing it up for the first time.
Old 04-02-2013, 10:52 PM
thanks
Yes again you guys helped out..I did squirt some oil into the cylinders..and let it sit..i fired it up after some timing adjusments..and it sounds awsome..a bit of smoke at first but that cleared up...thanks again.
Old 04-03-2013, 12:01 PM
Glad it was a simple fix!
Jim
ceased perkins diesel jak327 Engine 5 10-06-2009 10:14 AM
Rollerized Cleavland ? "70" Cougar Engine 1 12-14-2006 07:41 AM
ceased engine tbirdscott Engine 7 06-03-2006 07:34 PM
Cleavland On A Windsor nicowarrenrogers Engine 2 04-22-2005 01:31 AM
351 Cleavland valve seals ImaPseudonym Engine 6 10-28-2002 04:43 PM
