Originally Posted by arturo41
My signal lights take a long time to work when my headlights are on when I turn on passenger side signal the driver side cums on to
Listen to the man he knows this stuff.
And they should (COME) on in the correct manner.
Originally Posted by vicrod
These types of problems are often caused by poor grounding of the lamp sockets. Make sure the lamp sockets are properly grounded to the body.
To find the problem, use a piece of wire that is connected to a good ground and, while the lights are operating, touch the end to the lamp sockets to complete the circuit path to ground.
Repair the socket by soldering a piece of wire to the socket shell and connecting the other end to ground. Sometimes are replacement socket will be needed.
vicrod
X2 do as stated you should find your problem, and then they should (COME) on as they should.IMHO
Cole
