There is some good info on Comp Cams website about this very topic. It gives you the pros and cons so you can make the best choice. Read here
http://www.compcams.com/technical/FAQ/LSAproperties.asp |
That is a nice summary of events. I'm wondering how much torque increase there will be with only a 2* narrowing of the LSA. May or may not be worth the expense, but a torque increase would sure help the street use of the truck.
Whatever happened to Techinspector1? He used to crunch these numbers! |
Here is another article based on 3* LSA differences. They have crunched the numbers at the bottom of the page. Hope it helps. http://www.chevyhiperformance.com/te...t/viewall.html |
Edelbrock cams aren't exactly known for quality. And those heads canuse some porting. That being said good head work and a custom cam from a good grinder would probably get you at least 50hp. You're looking at over $1000 to get that done though.
Thanx much. That seems to be just about what I was looking for. Hardly looks cost effective for a couple of lb/ft and a couple of horses. Looks like if I want a noticable increase I'd need to go with heads, cam and larger carb. I don't need a few ponies THAT much! |
Have you given any thought to changing the cam phasing by advancing it a few degrees? Depending on the whether the cam is ground w/any advance already, that could get you some positive results. Edit- Never mind. It already has 5 degrees of advance ground in (107 degree intake c/l on a 112 degree LSA). No need for 1.6 rockers, the lift is sufficient as-is for the heads. I'd say cam-wise it'll take a new cam to gain anything. Is the QF 680 a DP or vacuum? Annular boosters? Those carbs are hard to beat. It might be giving away a bit of peak HP but everywhere else it ought to kick ***. |
Fwiw edelbrock isn't a cam manufacturer, they just box and ship them.
Also for the runner and valve size the flow numbers are not spectacular at all. Flow is not everything of course but its a good start. As for all my pieces of paper I'll be the first to say they are way too easy to come by and I still don't have a phd, which is the only degree that means anything any more. Also I get my hands dirty but perhaps less than others as those silly little books ensure I get it done right the first time. Only in America would working smart instead of hard be frowned upon. |
We have no machinists around here so porting, and basic engine machining must be done about 60 or 70 miles away. Can't even get a valve job here anyomre. Years ago we could go into any parts store and have heads done, block bored/honed , balh blah. Not now. So, shelling out the cash for AFRs or Trick Flows, plus a cam, etc to gain 50 HP is just not cost effective. What I will probably do is pull the heads, lap the valves, gasket match the intake and intake ports on the head and reassemble. Fine tune again and then run the dyno at Fun Run next year just to check the difference. Plus, TI came up with about 441 HP and 471 lb/ft on desktop dyno. Well, my numbers are 380 and 396 respectively at the wheels,. Using the standard 20% loss for an automatic trans that brings me to about 475 HP and about 495 lb/ft of torque. Thats not bad for a pretty mild small block. |
As for the carb, if you're happpy with it keep it but a well tuned 800cfm or larger carb that is properly built will show gains from idle to redline, but its not cheap. |
| Lobe separation for nitrous on custom grind Lunati | TorkMonster400 | Engine | 14 | 06-29-2008 03:00 PM |
| Separation anxiety - early Ford drum brakes | Centerline | Suspension - Brakes - Steering | 11 | 03-21-2008 02:35 PM |
| 6-71 Blower: 2 Lobe vs 3 Lobe, Straight vs Helical | Brian S | Engine | 0 | 04-11-2006 12:58 AM |
| Is a 108 Lobe Separation 2 Much? | lakecityg | Engine | 9 | 07-03-2003 07:35 PM |
| lobe separation | charles | Engine | 1 | 03-05-2003 07:34 AM |
