Signs OF Bent Pushrod Or broken valve Springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2010, 01:05 AM
hey guys i need to know if you can help me diagnose the sounds of (if any at all) on how i would know if i broke a valve spring or bent a pushrod all i can tell you is its a 79 400 sb chevy 100 percent stock no peformance what so ever and after the snow it started knocking like crazy u can hear it clattering all around the truck and idk what is wrong and when your driving it you can hear something clattering but it only happens when its ideling or when u hit a certain rpm and if you give it a little bit of gas when your cruisin around please help me anyway possible thanx
Old 03-24-2010, 01:12 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The easiest way to "see" a bad spring or valve in general w/o removing the v-cover, is to use a vacuum gage. If the needle oscillates in time w/the miss or noise, that's an indication that it's valve related.
But, it sounds like you may have a bearing going bad. If you have an oil pressure gage, keep a close eye on it for lower than normal pressure- but the best thing is to stop driving it yesterday and properly diagnose the problem before the engine is trashed.
A length of fuel hose held to your ear or a mechanic's stethoscope can help to isolate where the noise is coming from.
Old 03-24-2010, 04:50 PM
reply
thanks cobalt but the hardest part is ive used the stethescope and cant hit the noise anywhere cuz its so loud and its not on either side of the block its all around and idk what to do other than pulling the block and ripping it down
Valve Springs Lift juiced66malibu Engine 2 03-08-2008 11:54 AM
valve springs, valves, push rods, and rocker arms elcaminodragster Engine 7 01-28-2008 08:48 AM
what are the sign's of weak valve springs? tiresmoke55 Engine 6 09-09-2006 08:33 PM
Fan hit upper rad. hose!! mustangdude947 Engine 14 08-19-2004 03:52 PM
Broken valve spring??? Miligav383 Engine 6 05-16-2004 09:40 PM
