Sikkens Autoclear III - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2011, 03:26 PM
I am fairly new to painting and have a couple of questions about Sikkens Autoclear III.
A relative of mine moved, but left some paint in the garage that he said I could have.
- 1 Gallon of Sikkens Autoclear III
- 1 Gallon of Sikkens Standard Reducer
- 1 Gallon of Sikkens Standard Hardener
- 2 quarts of Silver Paint
- 1 quart of a clear unknown liquid which I am assuming is Sikkens Standard Activator
My questions deal with Autoclear III.
Here is the technical data sheet:
http://www.globalsafetynet.com/akzon...20_english.pdf
The Technical Data Sheet says to mix Clear, Hardener, and Activator
I always thought Hardener and Activator were interchangeable terms, so as of now I am a bit confused.
1. What does hardener do? I am assuming that it is the catalyst that allows the paint to cure.
2. What does activator do? The Datasheet says it is a reducer (thinning agent), but why is it called activator?
Old 10-13-2011, 07:12 AM
BarryK's Avatar
The data sheet tells it all for what you need to do, so not sure what the question is.
The third component is reactive for a good reason, so if your planning to re-engineer, you will get in a pack of trouble.
Its a good clear and since it was free, I would not look a gifted horse in the mouth.
Sikkens color build pluss question no ametures please!! painted jester Body - Exterior 65 03-17-2011 08:59 PM
Sikkens Autoclear Daz_uk Body - Exterior 0 05-26-2008 03:10 AM
Iwata LPH400 w/Sikkens schatzy Body - Exterior 14 08-15-2007 09:02 PM
sikkens or ppg's omni???? Mopar_Truck Body - Exterior 10 10-09-2004 08:38 AM
