Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - silver metalic problem
Old 01-31-2006, 05:03 PM
yeepman2 yeepman2 is offline
Last night I sprayed the roof of a gto with nason bc/cc silver mixed 8-1/2-4.Spayed two medium coats with sata 2000 hvlp 1.4 mm tip.Had lots of mottling and stripping so i spayed several drop coats and ALMOST got it.sprayed at 29 psi with the trigger open like sata recommends,but i'm getting a very small pattern,about 5 inches,and its kinda football shaped.I've read about using clear activators to stabilize the metalics,is this needed when using nason basecoat activator?
