Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - silver metalic problem
Old 02-01-2006, 12:53 AM
gdroze gdroze is offline
ive shot nason for about 15 years and i have always disliked there base coat system. with light colors like silver it is best to go with the slow reducer like
441 22 or low voc 441 66 .i use a sata 2000 with a 1.3 and it works fine .also
make sure to open the fluid as much as possible keep the gauge around 25, and
a medium wet coat and let it flash off and it should look right.also use a 1 to 1
mix ratio works best. you dont need activator even though it is called for. but if you must add one ounce per sprayable quart
