Silver Metallic blotching - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-22-2005, 09:55 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Well IF I was using an intercoat clear I understand the build being an issue but even Kos say's to over reduce it for Kandy. After Jim's recommendation of treating (reducing) the intercoat like a base paint,as in THIN,less build with coats, As much a 1:2, It went much better. Just be warned that this much reduction will cause 2 issues.
1. It RUN'S VERY EASY, So following the usual recoat while still wet not stringy is out. It has to be almost dry before applying next coat along with good gun technique/speed.
2. Use GOOD TAPE. The extra solvent will wreck average tape and even the blue fineline get's a little "soggy". I had a couple of bleed thru's on the mask but it seem's to have cleaned up with the scotch pad from the look's of the first clear coat.
I am using a NASON BINDER not intercoat clear. This is part of the experiment.
This product IS thick like the IC so reduction has been best at 1:1-1/2 or so.
I am trying to NOT spend a fortune playing around with Kandy's & graphics so the binder was substituted in place of the IC till I get the hang of this "Custom Painting" gig. The IC is just a "covering" for further graphics as well as a transport for the kandy. I did not need a cover,just a transport.
Yeah I know, But nobody ever said I was sane.
One other thing, My Avatar pic, That's the top lid on my tool box.
AND,
Try as I might, I STILL can't freehand stripe for shemp.
  #17 (permalink)
Old 05-23-2005, 01:28 AM
Last journal entry: metal finish
Nason base coat never covers good with the 1:1 ratio.. i usually do the 2:1 ratio for it to cover good and even then some colors just need more coats.
help wetsanding metallic paint?? imp0rted1 Body - Exterior 9 07-11-2008 11:02 AM
Gary Myer's Mustang aka Silver Bullet TNTster Hotrodders' Lounge 2 09-15-2004 10:56 AM
Whats The Deal With Silver Paint??? 41chev Body - Exterior 24 10-20-2003 02:24 PM
Metallic Re-paint bruce-77346 Body - Exterior 1 06-20-2003 09:23 PM
Metallic Paint - splotchy look bruce-77346 Body - Exterior 1 05-25-2003 08:09 AM
