Silverado differential cover size - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2011, 06:35 PM
I need a new diff cover for my 2000 Silverado 2500 6.0L 4wd. There's a a couple different options. I need to know what size ring gear I have, 9.5 or 10.5. It's a 14 bolt
Thanks
Old 05-14-2011, 07:05 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
I believe most 2500 6.0s have the full floating rear axle, which would be the 10.5" ring gear. There were some "light duty" 2500s that still had 8 lug wheels (at least some of those had the 5.3) but the semi-floating 14 bolt, those had the 9.5" ring gear. Take the center cap off one of your rear wheels to see if you have the full floating axle or the semi floating.
I too have a '00.
Old 05-14-2011, 07:29 PM
Altec's Avatar
Bottle Of Whiskey
If we could get a picture of the rear cover I would feel more comfortable in saying what it is. Around that time is when the AAM axles started showing up.
Old 05-14-2011, 07:45 PM
Blazin72's Avatar
Wiki Edits: 19
The AAMs showed up in the 01-up Silverado/Sierra HDs with 11.5" ring gears. The 99-04 "non-HD" 2500s used the 9.5 (semi floating) and 10.5" (full floating) 14 bolts. The 1500 HDs also used the 9.5' 14 bolt.
This may help too:
https://www.4wdfactory.com/store/cat...al-Motor-Axles
Old 05-14-2011, 07:54 PM
Altec's Avatar
Bottle Of Whiskey
Randy lists both the 10.5 and the 11.5 for 2000 in the Silverado 2500 (Non-HD).
Very confusing. Wonder if there is a GM Light-Duty expert around here that can chime in? Can't help but wonder what options gets what axle.
Old 05-14-2011, 08:17 PM
Blazin72's Avatar
Wiki Edits: 19
What's even more confusing is that 8600GVW 2500s in 99 and 00 were also called "HDs". My truck that I posted above is the "HD" with the 10.5" ring and pinion. The 9.5" semi-floating 2500s had a 7200 GVW.
http://dieselpower.automotive.com/10...dup/index.html
http://en.wikipedia.org/wiki/10.5%22...t_Differential
When you mention "Randy", are you talking about Randys Ring and Pinion? I checked it out and I think that's a mistake. My GM service manual (which covers all full size Chevy and GMC pickups and SUVs) lists an 8.5" (for half tons), a 9.5" and 10.5" ring gear. There is no 11.5" listed, those came out with in 2001 along with the 8.1L and Duramax.
Old 05-14-2011, 08:25 PM
Yea it's kind of confusing.. I have a picture of the rear pumpkin on my phone.. I'll upload it later when I get to my computer.. How would I tell if it's a full floating or semi floating.. I ordered a diff cover from Autozone for a 10.5, it was only $20.. Got a feelining its gonna be the wrong one but dunno.. I can always return this one when it comes in if it's wrong
Old 05-14-2011, 08:27 PM
Mine looks like the one in the pic. I have a long bed and I have different stock wheels.
Old 05-14-2011, 08:32 PM
Blazin72's Avatar
Wiki Edits: 19
Pull the center cap off the center of the wheel. The lug nut covers usually just twist off with a 1/2 turn or so. On mine they frequently come loose and I can usually just lock them back in place by hand. After the cover is off, if you see a ring of 8 bolts then you have a full floating axle. If you see nothing then you have the semi floating axle.
Again, the full floater is the 10.5" ring and pinion. The semi floater is the 9.5" ring and pinion.
With a full floating axle you can pull the axle out of the housing with the rear wheels sitting on the ground.
With a semi floating axle you have to jack the truck up, remove the rear wheels, drain the differential and remove the cover, remove the spider gears, pull the c-clips. After all of that, you can pull the axle out of the housing.
Old 05-14-2011, 08:34 PM
Blazin72's Avatar
Wiki Edits: 19
If yours is like mine then you most likely have the 10.5. Pull the center cap and take a picture.
Do you have the chrome or painted steel wheels?
Old 05-14-2011, 08:37 PM
Mine are the chrome wheels.. I think they're actually chrome covers
Old 05-14-2011, 08:40 PM
prostreet6t9's Avatar
Differential/Driveline
The 10 1/2 full floater will have a bolt in pinion support. The 9.5 will not.
Old 05-14-2011, 09:14 PM
here's some pics
ID:	55329   Click image for larger version
ID:	55330   Click image for larger version
Old 05-14-2011, 09:23 PM
Blazin72's Avatar
Wiki Edits: 19
Looks like a 9.5
Old 05-14-2011, 09:26 PM
Altec's Avatar
Bottle Of Whiskey
Originally Posted by Blazin72
Looks like a 9.5
I agree.
1981 Parisienne differential size? abas_abas Transmission - Rearend 4 07-16-2009 08:52 AM
What size wheels and tires to put on my 85 Silverado? leastbay Hotrodding Basics 1 06-15-2004 03:11 AM
What size wheels and tires to put on my 85 Silverado? leastbay Hotrodding Basics 0 06-14-2004 06:54 AM
turbo powered differential cover? 409guy Engine 11 04-07-2004 08:35 PM
Differential cover Stinky Transmission - Rearend 3 06-12-2003 01:30 PM
