Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Silverado Idling problems
Old 02-05-2013, 09:31 AM
s-10again! s-10again! is offline
if not intake gaskets it could be a temperature sender/sensor. if the sender does not work the computer runs a default setting and adding fuel for a cold engine is not in the default settings. try your temp sender, or if not that maybe the computer itself is not compensating for the temperature mandated fuel needs. had this problem on my 99 tahoe 5.7. it was the temp sender/sensor.
