Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Silverado Idling problems
Old 02-05-2013, 10:46 AM
joe_padavano joe_padavano is online now
First of all, you cannot "disable" the "check engine system" on an OBD II system - it's integral to how the computer works. What was likely done is that the Check Engine light on the dash was disabled (ie, bulb removed) or something similar. Plug a diagnostic tool into the OBD II port and I guarantee you'll get a data stream out.
Of course, the first problem will be all the codes pertaining to the cats being gone...
Given how little restriction modern cats add, I continue to struggle with why people waste the time and money to do this.
Work through the codes and figure out what is going on.
The Following User Says Thank You to joe_padavano For This Useful Post:
LATECH (02-05-2013)
