Be sure to drill steam holes in the 307 heads for a 400sbc if you use the 307 heads
Here is a page on the 400 SBC steam holes.
A 165 thermostat is more appropriate given the 400's steam hole cooling system.
Any crossover head in use,other than a 400,needs to be drilled for the 400's steam holes. |
Ok so this is completely different then how I have always set up a carb fitting on the intake to the trans rear base to the break booster front to the pvc also I do kno the dates and will look at the wholes just I'm almost certin there the same ones iv always used
Stem holes have been drilled and heads resurfaced
Typo
Should read to the front port, not the rear. Rear can be the booster if you want or the manifold- it doesn't matter as long as its large enough and is manifold vacuum.
| Some fairly simple questions | RatRodder1233 | Hotrodding Basics | 4 | 03-24-2010 01:29 PM |
| Help. 2 Simple questions | chappell | Hotrodding Basics | 5 | 02-14-2008 09:28 PM |
| Some simple questions ref. my 67 Pontiac | tk421 | General Rodding Tech | 2 | 12-21-2007 08:14 AM |
| simple 700 questions | NXS | Transmission - Rearend | 12 | 11-21-2004 10:55 AM |
| help on simple 351w Questions | grover805 | Engine | 3 | 10-17-2003 11:37 PM |
