Simple fuel line question
I did a search and I could not find what I was looking for. I was just wondering how you measure fuel line. Is it the inside or outside diameter that you measure.
Thanks |
Inside diameter
neopreme line is measured on the inside, metal line is measured on the outside.
thanks I was hoping for outside but now I know thanks again
I have steel line and mesured it was 3/8 on the outside so it is 3/8 or 5/16 or something else?
If it is 3/8" on the oustide how could it be 3/8" on the inside?
You have to allow for the thickness of the tubing. |
sorry I might have worded that wrong, I was just told to run 3/8 fuel line and was wondering what I have now, and it is 3/8 on the outside
I can't say for sure if it is inside or outside diameter. I have always just run new line to start out with. I get aluminum line from the hardware store, and the flaring tool. I get the 3/8" flare nuts and call it good. It is cheap, easy, and aluminum is easy to work with.
Measurement is the inside diameter.
| All times are GMT -6. The time now is 07:04 PM. |
