Simple fuel line question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2005, 09:55 PM
red_rider52's Avatar
DriveItLikeItsSupostToBeD riven
I did a search and I could not find what I was looking for. I was just wondering how you measure fuel line. Is it the inside or outside diameter that you measure.
Thanks
Old 03-07-2005, 10:04 PM
Inside diameter
Old 03-07-2005, 10:06 PM
milner's Avatar
neopreme line is measured on the inside, metal line is measured on the outside.
thanks I was hoping for outside but now I know thanks again
Old 03-07-2005, 10:50 PM
I have steel line and mesured it was 3/8 on the outside so it is 3/8 or 5/16 or something else?
Old 03-07-2005, 10:54 PM
lluciano77's Avatar
If it is 3/8" on the oustide how could it be 3/8" on the inside?
You have to allow for the thickness of the tubing.
Old 03-07-2005, 10:56 PM
sorry I might have worded that wrong, I was just told to run 3/8 fuel line and was wondering what I have now, and it is 3/8 on the outside
Old 03-07-2005, 11:00 PM
lluciano77's Avatar
I can't say for sure if it is inside or outside diameter. I have always just run new line to start out with. I get aluminum line from the hardware store, and the flaring tool. I get the 3/8" flare nuts and call it good. It is cheap, easy, and aluminum is easy to work with.
Old 03-07-2005, 11:08 PM
Lonestar's Avatar
"May the Schwartz be with you"
Last journal entry: Finally getting going...
Measurement is the inside diameter.
Fuel Injection Fuel line Plumbing william27103 Engine 9 06-10-2011 06:22 PM
fuel cell question??? fireforsin Engine 10 06-11-2008 07:28 PM
Carb size to small???? brainsboy Engine 50 08-14-2005 05:04 PM
fuel tank question HARVICKx29 General Rodding Tech 2 09-07-2004 04:22 PM
Dumb Question on Fuel Delivery Dottrz Engine 4 09-04-2003 02:32 AM
