a simple headlight mount clean up mod - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-30-2008, 06:53 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
The following pictures show a simple mod that requires no refinishing, just a cut and install.
The problem: on the bottom of the headlight bucket the mounting pad flares out. When installed the flared part hangs over the edge of the mount post . . Making the joining of the parts look mismatched.
Solution: Cut the flared mount off, after that you will need to replace that flare mounting area that was remove. In order to set and hold the lights adjustment.
Solution to that: a fender washer ........ how simple id that? see pictures
Enjoy
ID:	35276   Click image for larger version
ID:	35277   Click image for larger version
ID:	35278   Click image for larger version
Proper angle to mount the radiator? hduff Engine 3 02-11-2008 12:10 PM
Engine Mount Advice duncan_m Engine 17 10-24-2007 09:16 PM
Calling the DOC..66 Impala headlight switch issue black66 Electrical 7 06-01-2006 03:46 PM
Fan hit upper rad. hose!! mustangdude947 Engine 14 08-19-2004 03:52 PM
