Simple Line lock question
I have a line lock i want to install on a dodge rumble bee. it is an automatic trans with a slightly modded hemi. I want to install for some local burnout contests and whatnot. Tell me if this will work.... if i install the linelock solenoid in the rear brake line and activate it via switch, will it keep fluid from going past the line lock to the rear brakes or do these valves act as a check valve, and still push fluid through and then holds it so they stay locked?
