Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Simple Line lock question
Old 11-03-2012, 05:08 PM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is online now
Line lock solenoid/valve is a simple shut off valve. You press down on pedal then hit switch. Remove foot from pedal and the unit holds the trapped pressure in the line. Usually the front line. If you want to spin the rear tires.
