Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Simple Line lock question
Old 11-03-2012, 06:51 PM
poncho62's Avatar
poncho62 poncho62 is offline
Wiki Edits: 5
Originally Posted by jmcollins77 View Post
I have a line lock i want to install on a dodge rumble bee. it is an automatic trans with a slightly modded hemi. I want to install for some local burnout contests and whatnot. Tell me if this will work.... if i install the linelock solenoid in the rear brake line and activate it via switch, will it keep fluid from going past the line lock to the rear brakes or do these valves act as a check valve, and still push fluid through and then holds it so they stay locked?
You could do that, but why? You would shut off the rear brake line, but would still have to hold the brake pedal down to lock your front brakes to do your burnout.
