Simple Line lock question - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-03-2012, 03:03 PM
I have a line lock i want to install on a dodge rumble bee. it is an automatic trans with a slightly modded hemi. I want to install for some local burnout contests and whatnot. Tell me if this will work.... if i install the linelock solenoid in the rear brake line and activate it via switch, will it keep fluid from going past the line lock to the rear brakes or do these valves act as a check valve, and still push fluid through and then holds it so they stay locked?
Old 11-03-2012, 05:08 PM
BOBCRMAN@aol.com's Avatar
Line lock solenoid/valve is a simple shut off valve. You press down on pedal then hit switch. Remove foot from pedal and the unit holds the trapped pressure in the line. Usually the front line. If you want to spin the rear tires.
Old 11-03-2012, 05:51 PM
poncho62's Avatar
Wiki Edits: 5
You could do that, but why? You would shut off the rear brake line, but would still have to hold the brake pedal down to lock your front brakes to do your burnout.
Old 11-03-2012, 07:17 PM
Well, that is where the "whatnot" comes in play, i would also like to be able to play around.... say rolling at about 25-30mph, lock the back brakes out so they dont catch, and start feathering the front along with throttle for a rolling burnout. Again all just for play.
Old 11-04-2012, 01:01 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Go for it- the line lock could care less what you use it for- it'll lock out the rear brakes as easily as it will lock on the fronts- depending on how it's plumbed. Just be sure your insurance premiums are up to date...
We've talked about using line locks in unorthodox ways before: Line lock for handicapped
Old 11-04-2012, 07:57 AM
Thanks Cobalt, this was the answer i was looking for, that it doesnt matter where i put it, its gonna do the trick.
Old 11-04-2012, 08:30 AM
poncho62's Avatar
Wiki Edits: 5
Sounds like a...."Hey, hold my beer and watch this" moment coming up......
Old 11-04-2012, 03:42 PM
It will be filmed, if anything "Interesting" Happens i will post. Recently found a new "PLAY" place, a huge abandoned parking lot where a warehouse was torn down has been leased by a good friend, and until he starts building back, were gonna have some fun.
Line Lock Question Job~Rated Suspension - Brakes - Steering 7 11-19-2009 06:34 AM
Simple Radiator Question for a simple person 2000jack Engine 13 07-11-2008 12:47 PM
Line lock Question? red_rider52 Hotrodding Basics 1 07-19-2007 07:53 PM
Simple fuel line question red_rider52 Engine 8 03-07-2005 10:08 PM
Ford spring lock fuel line coupling question dirtlmfan Engine 5 07-09-2003 10:52 AM
