Simple Question From A Novice - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-26-2005, 01:32 PM
I have a straight stock '78 4 bolt main 350, what would be the pros and cons to me using 20w-50 oil in it as opposed to 10w-30. I know I would probably get better gas mileage with the lighter oil but are there any other benefits to using 10w-30? Do anyone know what the manufacturers reccommendation is for a '78 chevy 4-bolt 350? I'm just really curious, thanks.
Old 06-26-2005, 02:00 PM
topfuel's Avatar
ASE Certified Master Machinist
Last journal entry: More Pics
kdj, you would be better off running the 10w-30 for a few reasons. Aside from possibly getting slightly increased mileage, the engine parts will see lubrication quicker on start up and the engine will produce slightly more hp. Most manufacturers used the 10w oils in the late 70's. You always want to run the lightest weight oil that will provide the proper lubrication for a given application.
Old 06-26-2005, 02:17 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
The oiling systems on Chevys are supurb.
Use a normal 30 or 40 weight, change it regularly and you will have no problems. HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 06-26-2005, 03:54 PM
Thanks, you guys insight is appreciated.
A simple Question screamin340 Hotrodding Basics 3 05-15-2004 08:39 AM
Blower pressure (simple question) blown81 Engine 3 02-18-2004 06:37 AM
Simple Smog Question 77chevy400 Engine 12 11-28-2003 01:03 AM
Simple Question Dbodily Engine 2 11-11-2003 01:01 PM
simple brake lite question ( simple for you) dontknownuttinboutnuttin Electrical 7 12-08-2002 05:58 PM
