Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Simple Radiator Question for a simple person
Old 07-10-2008, 09:18 PM
2000jack's Avatar
2000jack 2000jack is offline
1929 Chopped Tudor
Last wiki edit: How to title a hot rod
Last journal entry: 1927 roadster
Wiki Edits: 3
Originally Posted by johnnya
The fan being on backwards would still move the air the same direction, just not as effeciently. Sounds to me like the fan is pitched backward from the proper rotation.
Can you post a close up picture of the engine fan?
JA
I was looking in Summit and that have photos of fans for reverse directions. I was going to check the fan against that. Also I will probably take it off and check for a part number and see if it has one and double check the application. If you go this web site you will see a picture of the engine, not the best photo though, but it shows the fan. http://www.hotrodhotline.com/feature...oodmansee0422/
