simple wiring for 700r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2009, 08:34 PM
I read some where that you can run a wire from "A" to "D" and the lock-up will work. Now the letters may be wrong, but the main thing was it is plugged into one pin and to another. It was a jumper set up. One wire from one hole to another. Can anyone get me straighten out on the confirgeration for this and what it does? Thanks
Old 11-11-2009, 12:48 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
your information would be incorrect.
you need 12 volts to the "A" terminal hole on the 4 hole connector.
A ground to the "D" is needed. If converter lock up happens depends on the design of the internal wire harness of the transmission
Old 11-11-2009, 01:42 AM
SSedan64's Avatar
700R4 Lockup Wiring
Lots of 700R4 Lockup wiring/diagrams Info here>> http://www.rowand.net/Shop/Tech/LockupTCCWiring.htm
Old 11-11-2009, 06:03 AM
sqzbox's Avatar
My pipes are my music
Here's a simple manual lockup system you can do. You can run a wire from term "A" to term "F" on your ALDL connector with a toggle switch, and lock up the converter In second gear on up (no lockup in first). Just remember to unlock it when decelerating or taking off from a stop to prevent damage to the converter.
Old 11-11-2009, 01:50 PM
I will place a toggle switch in a Keyed power source wire to "A" and grd."D".
Thanks
Old 11-11-2009, 05:47 PM
302 Z28's Avatar
Vince
Old 11-18-2009, 01:54 PM
My trans is a '91 700r4, without any electronics. The 4pin style. Thanks to all.
Simple Emergency flasher jgrant Electrical 13 06-09-2008 04:05 PM
EZ Wiring HELP! jaeger01 Electrical 19 06-23-2007 03:05 PM
EZ wiring project zipfactor Electrical 3 05-21-2006 03:55 PM
Alternator Wiring question 65Stanger Electrical 8 04-29-2006 02:28 AM
Need Wiring Diagram for 71 Nova sonicse Electrical 5 01-24-2003 12:24 PM
