I just got a singer 111W151 in great working order. I got it to do some car and boat upholstery on (or learn to do it).
It came with a 1/4" welting foot. I am looking to get some other foot sets for it. I noticed that the rear presser foot for this machine come in two configurations. One with the shank 90 degrees to the other. I am sure you can change the orientation of the presser foot shaft but I cant see how to do it.
I did find the US Army manual for this machine but I doesn't tell how to do this. Does anyone know?
You don't need to change the shaft, you need to buy the correct feet for your machine. Different models use different style feet. On the 111W, the shaft for your rear foot has a slot that goes from front to back, and all the feet for that machine will take the same style feet. The rear foot is held on by a screw that goes in from left to right. The Singer 211W151 has rear feet that attach in a slot that goes left to right. Unless you're going to sew welts with welt cord larger than 5/32, you won't need any more welt feet.
Thanks for the reply. My presser foot shaft has the slot that goes left to right not front to back.
So in my research and from your confirmation, I believe that my machine is a needle feed and does not take the two piece walking foot sets.
Now I need to find a source for some different type feet for my machine. Of course, I may be premature since I'm not sure what I really need.
I know for my project I am going to want to do some top stitching so I'll need to find a foot for that. I found some zipper feet, left and right, maybe those will work well for the top stitching.
If it's a 111W, it is a compound feed machine (a combination of needle feed and drop feed) with alternating presser feet , which is another way of saying walking foot. The 151 designation must mean it is a special machine made for the government, 'cuz there's no mention of that particular model from Singer. I don't know why it uses the 211W feet, but that's what you'll need to get. It's also odd that the machine would be a "W", 'cuz that means it was manufactured in Germany which makes no sense if it was during WWII. Do you have the serial number?
If the 111W151 does not have alternating presser feet (walking foot) and is only needle feed, it will be very limited when it comes to auto upholstery. It would be better suited to sewing flat canvas, sails, or tarps. It would struggle to sew thicker things like sew foam. Compound feed means it has two ways to push and pull the work through the machine with feed dogs and needle feed as opposed to needle feed only. Home machines are generally needle feed only.
I had some time to clean it up, oil it and sew some marine vinyl last night
I did try to sew some vinyl to foam and it passed it through fine. My sewing technique however has a long way to go.
I do need to slow down the machine. I have ordered a small motor pulley and I am going to try that along with blocking the treadle to gain some control.
As it is now, I don't have much control over the speed, I can feather it to get the motor going but I don't have the touch yet to keep it at the slower speed. It likes to take off at full bore. I know about the servo motors, I'm not sure if I want to invest in one just yet especially if I don't have the skill needed to do my project.
I also need to figure out the correct thread tension trial and error I'm sure. I know how to adjust the top thread tension, I need to figure out how to adjust the bobbin thread and presser foot tension.
It sews through eight layers of marine vinyl with no problem. I don't think I'm going to practice on it much more until I get the new needles I ordered, the one that's on there came with the machine and I'm sure it wasn't helping my results. The new poly thread kept breaking but I can't attribute that to any one factor - it was probably a combo of thread tension, needle, and technique.
From the manual I can figure out how to thread the machine but it doesn't tell which way to thread the needle. I was threading the needle from left to right since that's the side the thread groove in the needle was on, does anyone know if this is correct?
You adjust the bottom bobbin tension by tightening or loosening the small screw that holds the front of the spring steel tension to the bobbin case. In the two pictures, the front screw is not there, but that's the screw that adjusts the lower tension.
The thread goes through the needle from left to right. The groove on the needle faces to the left. The scarf on the needle faces to the right. The scarf is the half moon shaped cut out just above the eye on the needle where the hook picks up the bobbin thread. Make sure you are running the thread through the thread guide just above the needle.
You adjust the foot's pressure with the wing nut on the back of the machine and the knob on top of the machine. In general, you want the pressure to be as light as it can be unless you are sewing really light fabric.
STOP!!!! No, the bobbin case doesn't need to come out, you can get to it without doing that. Don't try to take the bobbin case out unless you know what you're doing.
Ah, ok thanks, I wasn't going to take it out, I think the lower tension is fine. I just wanted to know where the adj. was. Thanks for telling me I can get to it without removal.
Ok, so in my earlier search to find out the difference of the foot types, I sent out a flurry of emails asking how to change the orientation of the presser foot. All of them came back that you can't - until today. I got this;
Now knowing my machine isn't a walking foot machine, what would this get me if this works and I did this? I would be able to use the rear foot of a two piece walking foot set, and maybe the front foot would fit on the needle bar.
Of course you can do that, and it's simple but what will that accomplish? On a walking foot machine the front part of the foot set does not go on the needle bar, it goes on a separate bar called the vibrating presser bar. Look at the picture. Your machine does not have the shaft right behind the needle bar like on my machine. You have needle feed, which means the needle moves forward to pull the work through. The foot intended for your machine has a narrow groove for the needle to be able to move forward. The rear foot for the walking foot machine has a wide opening to let the front foot, which has a hole for the needle to go through, and the needle move forward.
You can't make a walking foot machine out of your machine by using feet intended for a walking foot. If the presser bar shaft is in the same location on both machines, you could use the foot intended for your machine on a walking foot machine by turning the presser bar shaft 90 degrees and not using the front vibrating presser bar which would make the walking foot machine needle feed only. It doesn't work the other way around.
Thanks Dan, I did learn that and I know I can't make the machine a walking foot. I just thought it was interesting that after I learned that I got the email.
I worked/practiced with the machine more last night. I have a blanket jammed under the treadle and I found that if I used my left foot, I could control the machine much better. Must not be as strong as my right.
My stitches came out much better and I was able to stop at a corner, turn the piece and continue sewing. I turned out passable work, practice pieces of course.
Still making practice pieces. I got a much smaller pulley for my motor. I am now able to make the machine stitch very slowly. Boy does that help tons. Initially when I got the machine I thought I might not be able to do my project but with the machine moving slowly, I think I'll have a good shot.
I need to find something to mark the top of the vinyl to have something to follow when top stitching. I searched and found where Dan recommended the Fisher silver ink pens. I think I need to pick some up. How do you get the marks off of the vinyl after you're through?
Also, looking at welt cording, I see they have foam cord, I think this is what I should I should use for my boat's welt cord, is this right?
The silver ink comes off with a mild cleaner. Soap and water will do, or Fantastik or 409 spray cleaners work well too. Foam welt cord is fine for a boat project.
Hi Dan, have been watching your posts on upholstery, & I to are just starting out. You mentioned to MPM on the silver ink pens. Where do you get these as I am sewing on vinyl also. Thanks so much.
I have a question about the silver ink pen. Does it come in another color besides silver? Preferably red. Reason why i ask is because i had retina surgery about 2 years ago. Since them some things are difficult to se colorwise. At times i have a hard time seeing the silver ink.
Sorry, it only comes in silver. You could try a fine tipped red dry erase marker. I don't know if that would work as far as coming completely off of leather, but it should work on vinyl and Ultraleather. It would be worth a try.
UPDATE: I tried a dry erase pen on vinyl, and it does NOT come off.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
