Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Singer 211 G 166 - top button?
Old 02-04-2013, 12:53 AM
Bodnar720 Bodnar720 is offline
Kind of need to see a picture but its either for adjusting stitch size or its a safety clutch so if you do bad juju you can reset timing without having to have it repaired.
If so you just push it and rotate the wheel 2 times which ever direction the manufacture states to.
basically, if you get a rats nest inside the hook or break a needle ect, the hook assembly engages away to prevent damages, this button re-engages it, if I am correct that is lol.
