Singer 211 issue, bobbin case? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-09-2013, 11:00 AM
Made progress
I kept messin after my last post and got a very nice stitch after turning the machine manually and adjusting both top and bottom as i saw how the stitch slowly getting better.
Now that i see i didnt knock anything out in transport, I need to get my 92 size thread and 18 size leather needle in it and adjusted so i can continue on my pontoon seats.
I was told for sewing through four layers of vinyl that i should use a needle with a larger eyelet and it would prevent as many hangups... I havent found anything like this in a leather style needle. Is this true?
  #17 (permalink)
Old 05-09-2013, 12:02 PM
DanTwoLakes's Avatar
Wiki Edits: 22
I never use leather needles at all. I also use a size 21 or 22 needle for almost all my sewing, and those will easily go through as many layers of vinyl as will go under the foot of your machine.
  #18 (permalink)
Old 05-09-2013, 01:12 PM
preference of thread?
Im not having much luck now with the thicker thread. I was using v128 thread and an 18 leather needle on my household dressmaker and i almost finished a whole seat besides where it became four or more layers. The thread is "dabond" polyester i found on ebay...it worked well so i bought some v92 but it unravels very easily. Im having trouble with both threads in the Singer 211. (unraveling and getting hung up just above the needle eye; im making sure i hold the start of the thread to the "one o' clock" direction when i start.
  #19 (permalink)
Old 05-10-2013, 07:15 AM
Wiki Edits: 22
You need to take it to a pro to have it timed, have the tensions set, and have the machine checked for worn or broken parts. It's impossible to troubleshoot without running the machine myself, or seeing what it looks like.
  #20 (permalink)
Old 05-10-2013, 01:03 PM
Thanks Dan
I greatly appreciate all your help Dan. The machine was tuned just before i got it and runs great with the thinner thread it came with. I threw away the ebay crap i bought and just got a "sunguard" brand (92) from a local store and have had great success with a few tension adjustments.
One more question: when i stitch at a lower speed the top thread goes down the hole and gets hung up in the bobbin area. Is the take up/check spring an adjustment?
  #21 (permalink)
Old 05-10-2013, 02:08 PM
Wiki Edits: 22
Sungard is what I use for everything. No, there is no adjustment for the take-up spring on the upper tension. Are you sure you have the machine threaded correctly?
ID:	73914   Click image for larger version
ID:	73915   Click image for larger version
ID:	73916   Click image for larger version
ID:	73917   Click image for larger version
  #22 (permalink)
Old 05-10-2013, 02:09 PM
Wiki Edits: 22
Here's the rest of the pictures:
ID:	73919   Click image for larger version
  #23 (permalink)
Old 05-11-2013, 11:18 AM
My machine threaded
https://www.dropbox.com/s/xsqjuoh1ht...%2002%20PM.jpg
https://www.dropbox.com/s/w78vagi42z...%2035%20PM.jpg
https://www.dropbox.com/s/j0mz2eczdj...%2015%20PM.jpg
Last edited by adamvaughn; 05-11-2013 at 11:27 AM. Reason: not sure proper way to post pics
  #24 (permalink)
Old 05-11-2013, 11:45 AM
Two Issues
First Issue: These first two pics show the thread stay on the top side of the bobbin and then gets a little snagged just before the stitch is tightened up.
https://www.dropbox.com/s/po1v6xru3v...%2030%20PM.jpg
https://www.dropbox.com/s/ro5ht5881d...%2052%20PM.jpg
(you can see my screwdriver pointing where is snags....just a little.)
Second Issue: The next two pics show the thread pass smoothly past the part that it hung up on before but when it does, the thread puller sometimes catches the thread and splits it before it has time to tighten the stitch up and then it either gets hung up in the bobbin and skips a stitch on top of the vinyl.
https://www.dropbox.com/s/jz954beko7...%2053%20PM.jpg
https://www.dropbox.com/s/7rqjtj2zp8...%2055%20PM.jpg
Other than this occasional hangup, its sewing pretty good.
  #25 (permalink)
Old 05-11-2013, 12:21 PM
Wiki Edits: 22
Your threading looks fine except for the thread guide right before the two tension disks. Use the middle hole, don't loop the thread over the guide.
  #26 (permalink)
Old 05-11-2013, 12:47 PM
Close but no cigar
I feel Im being a nuisance but i know im so close. like i said in the previous post, its missing grabbing the thread underneath which makes it skip a stitch sometimes or it grabs the thread on the second time before the stitch has time to tighten up.
https://www.dropbox.com/s/jvyd18388g...%2055%20PM.jpg
i did rethread it like you said also.
  #27 (permalink)
Old 05-11-2013, 01:25 PM
Wiki Edits: 22
Try loosening the screw that holds the needle, and rotate the needle a small amount to the right. Sew with it and see how it does. If that doesn't work, try rotating the needle to the left a little. I can't really see anything wrong. It really has to be something simple. Are you winding your own bobbins? If so, find some pre-wound bobbins and see how they work.
  #28 (permalink)
Old 05-11-2013, 02:26 PM
The only prewound bobbin i have at this time is 138 and im working with 92. Though my wound bobbin wind isnt perfect, it stays taught and doesnt seem to hang up.
Turning the needle a little counter clockwise seemed like it might foward the thread just enough not to get snagged but didnt.
I know its way above my head but i saw a manual for the 211g describing adjustment for the bobbin casing and everything around it including the height of the thread grabber. I just dont understand why the thinner thread sews fine and this doesnt.
I think its time for a drink.
  #29 (permalink)
Old 05-12-2013, 09:06 PM
Detective work
https://www.dropbox.com/s/o10usfwy0s...%2042%20PM.png
This first pic is my problem. The thread grabber (if thats its name) catches the top thread on its second time around before the stitch has time to tighten up.
The next pic is of the machine threaded and if im not mistaken, the "take up" does have some adjustment (the two chrome disks move independently; the rear one allowing the small spring to sit low or high) which i thought would put more tension on the up stroke allowing the stitch to tighten before the grabber came around. This doesnt seem to be true. The only thing i can see that might be wrong is that spring sometimes gets hung up on the casing of the machine instead of resting on the intended disk (illustrated with the RED arrow).
https://www.dropbox.com/s/eq5yt8uyeh...%2012%20PM.png
  #30 (permalink)
Old 05-13-2013, 07:29 AM
Wiki Edits: 22
The take-up has nothing to do with it. I have been sewing for 40 years, and have never had to adjust it on any machine I've ever used. The hook is what picks up the bobbin thread, and that may need to be replaced. A complete hook with a new bobbin case is around $125 if I remember correctly.
Singer help ktreinhart2000 Interior 2 04-18-2011 08:27 PM
Which Bobbin? Coodeville Interior 2 08-28-2010 04:41 PM
Singer 201 DougMN Interior 2 06-14-2010 12:58 AM
Signs of A Bad Bobbin Case? Coodeville Interior 2 03-04-2010 10:10 AM
Bobbin Winder on 111W? Coodeville Interior 3 02-10-2010 09:14 PM
