Singer 211 issue, bobbin case? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2012, 12:50 PM
Hey guys, so the issues never end. I finally got my servo motor installed etc and I'm having issues with my machine. It worked fine for about 30 minutes, then I got some thread caught under the bobbin case and the issues have persisted since then. I had some thread caught under the bobbin case so I took it apart to pull it out, and now I suppose I'm not 100% sure everything is in its proper place. Essentially I'm having issues with the bobbin thread being fed properly. It seems like something is catching.
I took a picture of how I have it installed. Does this look correct? Is that C arm along the bottom supposed to prevent the bobbin case from fully rotating 360 or should I move it back to the right a bit? Basically seems like depending on where i screw it down it either blocks the bobbin case from spinning 360 or it doesn't. Also, I removed the piece of metal under the foot temporarily as that also seems to be causing things to catch. When it is attached I can't get the bobbin thread to be pulled up. When I remove it, the thread comes up and then I'm able to screw it back on.
Any ideas?
Old 01-14-2012, 12:58 PM
Another picture with everything installed.
Took a quick video too. On this one it actually pulled the bobbin thread up but you can see that it is a bit difficult. Often it just gets tangled and stuck.
or
http://s96.photobucket.com/albums/l1...t=IMG_0773.mp4
Also the result of sewing with that after it loaded.
Old 01-14-2012, 01:54 PM
DanTwoLakes's Avatar
Wiki Edits: 22
First of all, you got the bobbin case back in correctly, with the tang from the bobbin case trapped under the notch in the throat plate.
Secondly, the thread has to go through the thread guide at the bottom of the needle bar just above the needle so that the thread goes straight up and down.
If the thread is not pulling out of the bobbin case smoothly with just a little resistance, you have something wrong, like the bobbin is in upside down. The thread should come off the bobbin on the top side and unwind as you pull it to the left.
Look at these pictures, and you will see how it should be, including how to pick up the bobbin thread after changing a bobbin.
How are you starting to sew? You either need to hold both the top and bottom thread as you start, or plunge the needle down from the needle up position through the work before you start to sew.
The last thing that could be wrong is that the needle is installed wrong. The groove on the side of the needle faces to the left, and the scarf on the needle faces to the right. "You'd be surprised", my sewing machine repairman told me, "how many machines I get in here that have the needle turned the wrong way."
If any or all of those things aren't correct, you will get a mess like in your pictures.
ID:	61817   Click image for larger version
ID:	61818   Click image for larger version
ID:	61819   Click image for larger version
ID:	61820   Click image for larger version
Old 01-14-2012, 02:12 PM
Wiki Edits: 22
more pictures: The correct sequence goes from right to left. Starting at the second picture from the right, you are holding the top thread down to the table as you turn the hand wheel pulling back toward you. Once the hook picks up the bobbin thread and the top thread pulls it up through the hole in the throat plate, put anything in the loop of bobbin thread (in this case my small scissors) and pull the bobbin thread out completely.
ID:	61822   Click image for larger version
ID:	61823   Click image for larger version
ID:	61824   Click image for larger version
ID:	61825   Click image for larger version
Old 01-14-2012, 02:13 PM
Wiki Edits: 22
And one last picture: This picture shows where the thread should be when you start to put the work under the foot.
Old 01-14-2012, 02:39 PM
Wow thanks for the incredibly detailed response.
So as far as I can tell that is how I'm doing it. I'm loading the bobbin, pulling it through the slot on the bobbin case, and then placing it under the support and towards the back of the machine. I'm turning the machine by hand to get it to feed up and then pulling it through with the scissor as you demonstrate. Then when I start to sew I'm doing 2-3 stitches just turning the machine by hand without the motor, and then I'm starting it up. Now though I can feel it start to catch and not run smoothly after the first stitch or two by hand. It's getting caught on something in or around the bobbin case. I took another video showing the actual bobbin case getting jammed up and you can see how the thread is getting tangled. I also took another video below that of how I threaded the top needle if that makes any difference.
Thanks again Dan, truly appreciate it.
Dan
Video 1 of Bobbin Mess
http://s96.photobucket.com/albums/l1...t=IMG_0777.mp4
Video 2 of Threading of top needle
http://s96.photobucket.com/albums/l1...t=IMG_0778.mp4
Old 01-14-2012, 02:43 PM
Wiki Edits: 22
Dude: Do I see the end of the bobbin thread going up out of the hole in your metal bobbin, or is that my imagination? The thread does not go up through that hole after the thread is wound on the bobbin, it simply unspools off the side of the bobbin.
Old 01-14-2012, 02:57 PM
No it's not going up through the hole. That's a small bit left over from when I wound the thread on the bobbin bobbin. I just didn't cut it all the way to the hole. It's going the other way.
Old 01-14-2012, 03:40 PM
Wiki Edits: 22
Did you take the bobbin case completely out of the hook assembly? You would have had to take out two small screws on a retainer on the right side of the hook assembly that holds the bobbin case in place. If you didn't take the bobbin case completely out there could still be thread trapped under the case.
Look at this thread: CLICK HERE
Old 01-14-2012, 05:26 PM
Yes I did do that. In fact I dropped one of the screws which made for a fun half an hour
I figured out part of the problem. I didn't have the bobbin case in the right position (the tab which goes under the throat plate was out of the throat plate). I fixed that, and now the threading feeds much better, and it is easier to get the bobbin thread out, but now as I sew the bottom thread is incredibly loose (see picture below)
I took 3 videos showing basically my entire procedure of loading the bobbin and then starting to sew. Sorry for the quality, it was hard to hold my camera and sew, but hopefully this explains the issue and maybe shows what I'm doing wrong. I had trouble getting out the bobbin thread in the video just because it was one handed but it is much smoother now. However, my sewing is still coming out like the picture below. Do I maybe need to adjust the bobbin case tension spring by that screw on the side of the case?
Video 1: Loading the bobbin
http://s96.photobucket.com/albums/l1...&current=2.mp4
Video 2: Bobbin thread
http://s96.photobucket.com/albums/l1...&current=1.mp4
Video 3: Sewing
http://s96.photobucket.com/albums/l1...urrent=3-1.mp4
Picture, underside of stitch
Old 01-14-2012, 07:49 PM
Wiki Edits: 22
O.K. When the stitches are that loose on the bottom,it means the top thread is incredibly loose, or the bottom tension is incredibly tight. The bottom tension can't be that tight, so I don't think you have the machine threaded correctly. Look at this thread for how to thread the machine: CLICK HERE
After looking at your video, the thread guide above the top tension disc assembly is in the wrong place. It needs to be over to the right and down until it is about level with the top of the tension discs. The top thread needs to be firmly seated in between the two upper discs, or you have no top tension.
Old 01-14-2012, 09:21 PM
Yup, I actually got it going. Once I got the bobbin case set, I rethreaded the top needle and it started working. Phew!
Thanks again. Sorry for all the trouble.
Old 02-05-2012, 01:50 PM
Video 3: Sewing
First thing I noticed was that the tab for the bobbin case was not in the correct location.
Old 05-09-2013, 10:46 AM
Fairly skilled newbie here. Ive read the two threads ("singer 211 issue w bobbin" &" picked up a singer 111w153") about 20 times. I just got a singer 211 U567b and am having the same issue w bunching of the thread underneath.
Can someone help me get the basics down like...
*whats a good way of feeling the correct tension on the top side....being able to pull the thread through with needle bending a bit?
*bobbin tension...should it feel as taught as if i could dangle it with a little give like the bobbins from a smaller machine?
*my needle is in w the groove on the left side..ive had slightly better luck threading this from the left though i believe i read dantwolakes saying all the 211s thread from the right?
This 211 is probably way different from my dressmaker class 15 but i had fun playing with the tension on that and got it just right using 128 thread.
Sorry but i feel a bit desperate now that i havent found any good forums, youtube videos or a manual on this model until i came here.
Old 05-09-2013, 11:30 AM
Wiki Edits: 22
There is no good way to feel the top thread tension. The bobbin tension is very slight. There should only be mild resistance when you pull the thread out. The machine threads from left to right, all industrial machines are threaded this way. The needle goes as far up into the needle bar as it will go, the groove should be on the left and the scarf of the needle on the right.
Singer help ktreinhart2000 Interior 2 04-18-2011 09:27 PM
Which Bobbin? Coodeville Interior 2 08-28-2010 05:41 PM
Singer 201 DougMN Interior 2 06-14-2010 01:58 AM
Signs of A Bad Bobbin Case? Coodeville Interior 2 03-04-2010 11:10 AM
Bobbin Winder on 111W? Coodeville Interior 3 02-10-2010 10:14 PM
