singer 211 parts - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-03-2009, 11:53 PM
singer 211 parts
What is a good source for parts for a singer 211. My brother in law has one and lives in az.
Old 10-04-2009, 12:33 AM
DanTwoLakes's Avatar
Wiki Edits: 22
That's a very common machine, so parts are easy to find. There is a place in California that I buy all my parts from. It's called Cut Sew Service. They have a web site: www.cutsewservice.com
Old 10-04-2009, 07:54 AM
thanx much
Old 10-04-2009, 08:04 AM
Wiki Edits: 22
BTW, for some reason that web site doesn't seem to work after their normal business hours. Try it during week days, and remember they're on Pacific time.
Old 10-06-2009, 12:23 PM
My brother in law is still having problems with his singer 211. The tension on the top thread becomes excessive and breaks the top thread at the needle. The stitches however are loose. Any ideas on this. We replaced the top tensioner
ID:	41077   Click image for larger version
ID:	41078   Click image for larger version
Old 10-06-2009, 01:48 PM
Wiki Edits: 22
What size thread is he using? Heavier thread, like size 138 and up, does not need to be woven through the top thread guide like in the 1st picture. It should go through it like in the 2nd picture.
ID:	41080   Click image for larger version
Old 10-06-2009, 03:23 PM
He is using # 69 nylon thread. We had it working good the other day. He seems to think that the thread is binding up in the tensioner. The bobbin tension seems tight when stitching although manually pulling on it seems about like my consew which is working great.
Last edited by DanTwoLakes; 10-06-2009 at 05:02 PM. Reason: Violation of guidelines. Please see: general board guidelines.
Old 10-06-2009, 05:01 PM
Wiki Edits: 22
Do the stitches on the underside look normal? The picture you posted makes it look like there is almost no bobbin tension. Look at your bobbin case. I have had the little flat black spring steel bobbin tension get bent or break before, which resulted in stitches like you are experiencing. You also may have something jammed in there that won't let the bobbin thread go under the tension spring. The machine could also be dramatically out of time. Did you change the needle lately? Make sure the scarf (the flat area just above the eye of the needle) is pointing to the right, not the left. Believe it or not, my sewing machine mechanic told me that was one of the most common mistakes people make.
Old 10-07-2009, 03:00 AM
I think he had a mechanic come out last night and check it out. Will keep you posted. Once again thanx.......Steve
Old 10-07-2009, 02:03 PM
apparently a tune up did it. The tensions were way off.
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 04:07 AM
MOST ALL ^&%#@ REPRO PARTS ARE JUNK RANT. MARTINSR Hotrodders' Lounge 33 05-06-2010 08:22 AM
Prepping urethane bumpers and fiberglass parts? starquest Body - Exterior 19 12-21-2007 10:54 AM
2.3L parts cant seem to find any performance parts for it JustinHebel Engine 3 02-26-2006 12:49 AM
1964 Muncie M-20 parts question 1964 Oldsmobile 442 Transmission - Rearend 3 04-10-2004 10:25 PM
