Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - singer 211g bobbin frustration
Old 08-25-2012, 03:46 PM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is offline
Wiki Edits: 22
Don't try to tweak the bobbin case. Loosening the top tension accomplishes the same thing as tightening the bottom tension.
What do you mean by "small loops on the bottom of the material" If you have loops, there is something wrong other than the tension. Are you sure you have the machine threaded properly?
