singer 211g bobbin frustration - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-23-2012, 08:28 PM
hi, i wrote a few days back about my singer 211g i picked up on a trade. the needle that was in the machine was broken, went to reputable sew and vac store and he had every needle but not the one i needed. picked one up at a big chain sewing and craft store , but i'm not sure it is correct. it has a flatspot and mine was round. i installed it and needless to say it fit everything was where it was supposed to be according to the manual. my problem is i can't get the bobbin thread to catch and be pulled up through the needle hole. i have the singer manual i downloaded online, put the bobbin in correct way according to manual, slid the thread in the slot and put around back letting it hang out of door loosely and it wont catch. i'm pretty sure it's me not the machine. i purchased the propper needles from ebay, they will be coming in a few days. i'm thinking the needle is part of the problem, and the other part is me not knowing how it goes, as when i got it there was no bobbin in it. the manual was a free download and it is very grainey, so it is hard to tell where it really goes. maybe somebody has one of these singer 211 g 155's and they can send me a real pic or a video from thier phone of how it goes. any help would be appreaciated as i traded a running dirtbike for it and was told this was a good working machine. thanks .
Old 08-23-2012, 08:53 PM
Cape Cod Bob's Avatar
Don't no if this will helphttp://www.hotrodders.com/forum/singer-211g-156-a-214800.html
Old 08-23-2012, 09:03 PM
I read it, good read , but no info for me on bobbin, thanks!
Old 08-24-2012, 08:47 AM
DanTwoLakes's Avatar
Wiki Edits: 22
You need a needle system 135 X 17 needle for your machine. The needles with a flat side are for home sewing machines. When you get the right needle, it will have a round end and a groove going down one side. When installed, the groove faces to the left, and the scarf of the needle faces to the right. The scarf is a hollowed out area just above the hole in the needle, and it is where the hook picks up the top thread from the needle. The needle is installed as far up into the opening in the needle bar as it will go. Once you get the right type and length needle you should be fine. Look at this link from Schmetz needles: SCHMETZ Sewing Needle Dictionary
Also look at post #3 in this thread: Singer 211 issue, bobbin case? IT explains how to load the bobbin into the sewing machine.
Old 08-24-2012, 01:45 PM
yesterday i ordered Schmitz 135x17 sizes 15 and 18, and i'm using bonded nylon thread size 60. now its the waiting game.
Old 08-25-2012, 01:04 PM
needles are here
needles are installed properly, the machine sews ok but, i am getting the small loops on the bottom of the material. i need to make the bobbin tension tighter, the only problem is the screw is already as tight as it can get? does that mean it's worn out? can i take it off and give it a little tweak and put it back on and see if that works? or is this something that i have to look on line for? i just wanted to thank everybody for thier help, honestly this forum is the only one i trust for stuff like this. think about it, what did we do 15 years ago? you can literly have an answer for anything now a days!
Old 08-25-2012, 04:46 PM
Wiki Edits: 22
Don't try to tweak the bobbin case. Loosening the top tension accomplishes the same thing as tightening the bottom tension.
What do you mean by "small loops on the bottom of the material" If you have loops, there is something wrong other than the tension. Are you sure you have the machine threaded properly?
Singer 211G-156 lilsuz Interior 33 10-19-2013 11:15 AM
Singer 211 issue, bobbin case? danios Interior 30 05-13-2013 05:15 PM
bobbin thread ScottieB Interior 2 04-21-2012 02:10 PM
Newbie with an extra Singer 211G-156 Falesi Interior 2 11-27-2011 08:03 PM
Which Bobbin? Coodeville Interior 2 08-28-2010 05:41 PM
