Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - singer class 66
Thread: singer class 66
Old 05-07-2013, 02:47 PM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is offline
Wiki Edits: 22
Whatever machine that is, it does not have a walking foot. Walking foot is a term to describe a machine that has alternating presser feet. Such a machine has three separate vertical shafts. Two of the shafts hold the two halves of the foot, and the other shaft holds the needle. The next thing you need to do is replace the leather belts with rubber "V" belts of the same approximate length. The machine has a built in mechanism to run the machine faster or slower depending on which groove of the multi groove sheaves you connect together. The smaller the driving pulley is, and the bigger the driven pulley is, the slower the machine will run, and vice versa. This machine will sew two pieces of fabric together, but it's not going to be very good at sewing things that are thicker than that. I'm thinking this is more of an industrial garment sewing machine.
Can you take some pictures from the other side of the machine, and more close up?
