singer class 66 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-07-2013, 01:19 PM
vinyldude's Avatar
singer class 66
hello, was donated a singer class 66 I believe, not knowing very much about sewing machines, has a walking foot, i am not sure how to thread the upper thread or lower thread, any information i would appreciate, runs great, thank you
Name:	singer upholstery machine 004.jpg
ID:	73829   Click image for larger version
Name:	singer upholstery machine 001.jpg
ID:	73830   Click image for larger version
Name:	singer upholstery machine 003.jpg
Old 05-07-2013, 02:47 PM
DanTwoLakes's Avatar
Wiki Edits: 22
Whatever machine that is, it does not have a walking foot. Walking foot is a term to describe a machine that has alternating presser feet. Such a machine has three separate vertical shafts. Two of the shafts hold the two halves of the foot, and the other shaft holds the needle. The next thing you need to do is replace the leather belts with rubber "V" belts of the same approximate length. The machine has a built in mechanism to run the machine faster or slower depending on which groove of the multi groove sheaves you connect together. The smaller the driving pulley is, and the bigger the driven pulley is, the slower the machine will run, and vice versa. This machine will sew two pieces of fabric together, but it's not going to be very good at sewing things that are thicker than that. I'm thinking this is more of an industrial garment sewing machine.
Can you take some pictures from the other side of the machine, and more close up?
Old 05-24-2013, 12:13 PM
My family has had a treadle powered Singer in the family since I believe the late 1800s. Its built into a desk of sorts; for storing sewing supplies. All the ones with the larger flat worktop that Ive seen were the industrial type units, as Dan mentioned, but Im certainly not an expert by any means. Ours has a lot of gold leaf on the actual sewing apparatus itself.
Singer 111W153 vs Singer 500A udtoy Interior 3 10-20-2012 11:16 AM
class of 62 LHS nutheastah Introduce Yourself 3 03-05-2012 05:29 PM
What Class? jalopy45 Hotrodders' Lounge 0 04-18-2009 06:32 PM
my new class SBCfan04 Engine 10 08-19-2008 10:54 AM
class is in pigpen Engine 1 03-26-2005 06:31 PM
