We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #61
Old 12-12-2006, 12:07 AM
curtis73's Avatar
curtis73 curtis73 is offline
Hates liver, but loves Jmark
curtis73's barnstar
Wiki editor
Wiki Edits: 16
Originally Posted by Rick WI
And for heavens sake Curtis how in gods green earth is running 17:1 air fuel going to "show even larger power increase"? How in the world are you going to make power that that A/F ratio?
What I meant to demonstrate was that leaning out a fuel mixture (every combination is vastly different) can increase power. That's been known for years. Its just that with grooves, that ratio is leaner than without grooves... again, depending on the combo.
17:1 is a valid number, given that there are a few grooved combos running that exact ratio. Its simply that I believe that the grooves provide that environment and you don't. Simply disagreeing, lets leave it at that.
Old 12-12-2006, 07:47 AM
Jmark's Avatar
Jmark Jmark is offline
Ok, what is BSFC????
And while we're on lots of letters and what they mean, anyone know what the "BVD" stands for in the mens underware brand?
And just yesterday, I learned what "cow magnets" were!!! LOL (watching the history channel!)
Old 12-12-2006, 09:06 AM
Rick WI Rick WI is offline
Brake specific fuel consumption. It's a measurement of fuel flow into and out of the engine, via a return line. Measurement units are in lb's per hour of fuel per horsepower. .5 to .55 BSFC is typical on an average engine. .39 to .42 BSFC is indicative of a very efficient motor. Many, many, many variables go into a low BSFC result. Carbs have an impact, intake design is a biggie, cylinder heads, camshaft.
Old 12-12-2006, 11:31 AM
automotive breath's Avatar
automotive breath automotive breath is offline
...Automotive Breath, feel free to post the interesting results from that dyno test...
My involvement with the 360 Dodge testing was the groove layout and dimensions. Jessie decided on the test parameters.
Some important points to consider: The engine was not knock limited because of the fuel in use. The “after” test was run on the tune-up determined during the initial test. The modification lowered the compression ratio by increasing the chamber size by the volume of the grooves.
Looking back its likely that different results would be had if test parameters had been different. I believe the primary benefit of the modification is to reduce burn time resulting in reduced detonation tendencies. The test did not measure engine knock limitations.
The point that interest me was after the engine was delivered to the customer and it was installed in a car, it performed at 11:1 compression on pump gas with no detonation. This was a surprise to the engine builder.
Rick, Last weekend I was awarded “Sportsman of the Year” at the local race track because of my accomplishments regarding engine performance. You may be wondering what does that prove. To you maybe nothing, to me it proves that the people that know me and are involved with what I’m doing recognize my contributions to the sport.
Old 12-12-2006, 07:20 PM
Hippie's Avatar
Hippie Hippie is offline
Pulled up the specs on GM's HT383 crate motor which uses the same heads and cam as my build (decided to run the 14097395 Marine/Ramjet/HT factory roller) and has 9.1 SCR compared to my calculated 9.2. The HT383 is a 4.000" bore with a 3.85" stroke so I would say DCR might be slightly higher than mine. GM recommends this engine for light trucks using 87 Octane. I think I'm safe.........
Old 12-17-2006, 11:55 AM
xntrik's Avatar
xntrik xntrik is offline
Save a horse, Ride a Cowboy.
Originally Posted by automotive breath
.....The point that interest me was after the engine was delivered to the customer and it was installed in a car, it performed at 11:1 compression on pump gas with no detonation. This was a surprise to the engine builder.
.....I was awarded “Sportsman of the Year” at the local race track because of my accomplishments regarding engine performance. You may be wondering what does that prove. To you maybe nothing, to me it proves that the people that know me and are involved with what I’m doing recognize my contributions to the sport.
AB,
Congratulations and keep up the good work.
Thanks
x
Old 12-17-2006, 08:55 PM
Originally Posted by xntrik
AB,
Thanks
x
Thanks, The same day one of the cars I'm working with put down some impressive numbers. It's a late 80's Camaro with a 355 SBC and a T350. The weather was good and the car was working great.
60 ft. 1.299
330ft 3.997
1/8 6.258
mph 108.63
1000 ft 8.221
1/4 9.895
mph 134.22
Old 12-17-2006, 09:56 PM
xntrik's Avatar
Old 12-17-2006, 10:03 PM
This written by another one of the top EMC teams, from another forum.
I have been doing this for about 2 years now...
...and long story short, it works.
The increases in low end torque and stable low speed flame propogation are valid and is the increase in detonation resistance. Idle vacuum increases a bit too.
There are not really any HP benefits at the top of the RPM window but more so at the bottom and mid range.
I used them at EMC this year and two years ago with good results, our combo was pulled down to 1,900 RPM at WOT with an 1150 dominator with out missing a beat. No detonation at 10.5 to 1 nor 12.5 to 1 on pump premium :!:
Old 12-18-2006, 09:01 AM
coldknock's Avatar
coldknock coldknock is offline
I think Buick had something like this in mind when they made heads for the 3.8/4.1 V6's.
Larry
Old 12-18-2006, 02:25 PM
hotrodf1's Avatar
hotrodf1 hotrodf1 is offline
Chasing dreams with a ball bat
I love reading this stuff . . .
Especially the link to the EMC stuff - couldn't believe it when I saw those grooves in the pistons.
Sure seems like someone with that kind of knowledge and dyno time would be able to tell whether or not this was worth anything. Maybe his actions have said something . . ..
Old 12-18-2006, 03:22 PM
johnsongrass1's Avatar
johnsongrass1 johnsongrass1 is offline
Race it, Don't rice it!
Now why would they use "Ross Custom Pistons" but rossd doesn't make rings for it either? Whatever.
Old 12-18-2006, 04:55 PM
Larry
Hi Larry,
Nice porting! I have never seen that indention before.
GM decided to put an inclined plane in the LT1 heads during the 90s. This head has been milled removing some of the area; it is to the right of the plug. It looks like they were attempting to induce a swirl in the chamber.
hotrodf1,
This statement says it all,
“Our combo was pulled down to 1,900 RPM at WOT with an 1150 dominator with out missing a beat. No detonation at 10.5 to 1 nor 12.5 to 1 on pump premium”
Old 12-18-2006, 05:40 PM
The actual article mentions that they have no idea what those grooves did or did not do. There is no way you can infer they had any direct impact with the dyno results, as again it wasn't tested and verified. What you can draw a conclusion on though is the MANY other areas which contributed to that engine making power. Tight quench (.035), combustion chamber and piston designed to mirror each other, relocated plug location, attention to camshaft lobe design, intake manifold design and on and on and on. Many of those design elements were throughly tested and verified as stated in the article.
Old 12-18-2006, 05:52 PM
Rick,
I think you and I are talking about two different EMC entries. The quote I posted was not from the BMS team but rather from another top EMC team running grooved heads.
IMO every component of and engine that runs 12.5:1 compression on pump gas needs to be considered as part of the total package that is capable of doing something extraordinary. I'm sure the combustion chamber itself was state of the art design.
edit:
I responded too quickly, I should have realized you were responding to the quote in your post, sorry.
Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Singh's Grooves in Ported & Milled vortec heads on stock 350"
Stock 350 with 305 truck heads? CrazyT Engine 3 08-04-2009 01:15 PM
vortec vs phase 2 heads 71vegagt Engine 3 01-29-2006 05:12 AM
Exclusive parts for Vortec heads mgray Engine 1 10-16-2003 06:38 PM
Collection of Ported Vortec Heads (pics) Ken-96GMC K1500 SC Engine 2 06-08-2003 04:00 PM
350 heads or 305 H.O. heads????? crshrmn3 Engine 3 08-25-2002 08:51 PM
