single and dual groove pulleys - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2007, 02:01 PM
cardaddyo's Avatar
always the hard way...
specifically water pump pulleys. just got a new w.p. and it says it is not designed for a dual groove pulley.im running crank,w.p.,and alt. on a single groove(one belt)pulleys.what would i do if i wanted to run dual groove pulleys but kept the w.p.? would some sort of spacer work or should i just sit and stare at it til it hits me? other than returning the water pump,what can a guy do here?
Old 03-01-2007, 10:27 PM
54truck's Avatar
Crazier By The Minute
As long as the new duel groove pulley is on the crank and the groove closest to the block is the same distance as the single groove pulley that you have now it will not effect the existing water pump pulley.The outside groove can be used for power steering pump and /or air conditioning. I do not remember seeing a duel groove pulley on a water pump.Bud
Compressor - Single vs. Dual Stage cab Garage - Tools 28 09-06-2010 04:48 PM
Dual vs. Single Plane Intakes Ozz1967 Engine 8 12-23-2005 02:55 PM
single vs. dual tunnel ram upstand2 Engine 5 06-28-2005 04:30 AM
Single to Dual Master Cylinder swazo Suspension - Brakes - Steering 2 10-19-2004 08:00 AM
Single plane and duel plane manifold stonedchihuahua Engine 21 01-06-2003 11:56 PM
