Single flare Brake Lines - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2008, 07:25 PM
will single flare brake lines work on a brake system or one must double flare brake lines
Old 03-20-2008, 07:35 PM
Wiki Edits: 49
You MUST double flare all soft steel brake lines at 45 degrees. If not they will leak like a screen door in a submarine. The only exception is if you're using stainless lines which are single flared at 37 degrees and use special connectors.
Old 03-20-2008, 07:40 PM
Wiki Edits: 31
you could get a single flare to seal, if your lucky.. but even if you do, it's not gonna hold for long.. for as cheap as pre made lines are, just buy lengths in the size you need. double flare tools that actually work cost too much to justify the cost savings of buying bulk lines and fittings.
Must II brake lines 4EyedTurd Suspension - Brakes - Steering 3 02-25-2008 08:12 PM
Stainless brake lines, sealing flare fittings problems Ripped Suspension - Brakes - Steering 7 01-30-2008 06:39 PM
how to anneal stainless steel brake lines so i can flare them racer21m Body - Exterior 4 12-11-2006 07:37 AM
Braided brake lines garbock Suspension - Brakes - Steering 4 01-10-2005 08:56 AM
Chrome brake lines??? T5Bird Suspension - Brakes - Steering 6 02-16-2004 09:05 AM
