Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - single leaf spring
Old 12-29-2001, 07:40 PM
bears38 bears38 is offline
New Member
The mono leaf spring will usually ride better . Multi leafs must rub against each other as the suspention goes up and down . FRICTION ! Monoleaf has nothing to rub against -no friction . Plus to make up for a lack of a stack of springs , the monoleaf uses a stack of spacers that you can place on top of or under the spring to get the ride hight you desire . Also , use a good set of adjustable shock absorbers and fine tune the ride. Not much use in having a good riding spring and crappy riding shocks.
