Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - single-pattern cams VS dual-pattern cams
Old 01-18-2013, 07:41 PM
desmosis10 desmosis10 is offline
College kid into Muscle cars
Single-pattern cams VS dual-pattern cams., What is the difference between the two cams in performance, torque & Horsepower... For my small block i'm using AFR 210cc Competition heads I have 650lift hyd roller spring on the heads. I looking for help if u can explain, which one of the cams would be the best for a Street/Strip application for my SBC 383 engine to get me close to the 550 to 600 HP range to the flywheel but still can give excellent torque on the bottom end too? Just looking for some help if anyone can answer these questions for me, I'm just trying to build a Mean Street Machine...
1. Looking for the right duration @.50 to get me 560 to hp and good torque
2. will a hyd roller cam @.50 247/255 600/600lift lobe seperation 110 get me close to 560 to 600 with out losing bottom end power. Is this over kill for the street even tho its a street/strip engine build
