Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - single-pattern cams VS dual-pattern cams
Old 01-28-2013, 08:39 AM
desmosis10 desmosis10 is offline
College kid into Muscle cars
Originally Posted by vinniekq2 View Post
AFR heads are great.You have 300 CFM potential.Look at the 2 cams I posted ,similar by the numbers,but the solid appears to have a higher RPM range,,, there are reasons.
Why do you want to use a hydraulic?
note in the video the builder states that his carb is good for 20 more horse power when it could say use this carb with "these" parts?
you might consider 220 AFR heads?
I stepped up to AFR 227s
If you want to street drive this "550" HP engine,then consider a 434?
Yeah Im just trying to stick with my sbc 383... An I kno I can get 550hp or better just looking for the right cam, I have all the goodies to back that up for my engine, I just want all that hp coming from a 383 stroker.
