Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - single plane intake vs dual plane
Old 03-03-2003, 08:12 PM
mustang66maniac's Avatar
mustang66maniac mustang66maniac is offline
Ford Freak
Post
If its slow off the line with a dual plane, itll be slower with a single plane. Basically, youll loose low end power and torque, but it makes up for it big time in the upper rpm range. Since your cam is rated from 2600-7000, i say go for the single plane, most dual planes fall off at 6000-6500. You might want a lower gear ratio and maybe a higher stall converter to make up for the extra slugishness off the line though.
