Single Point Of Failure: Proportioning Valve - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2010, 01:20 PM
I have a 1950 F-1 Pickup with an aftermarket corvette-style disk/drum braking system. After putting several thousand miles on the truck, I somehow got air to leak into my rear brake lines (seemingly without leaking out). Now, since at least the mid-60's master cyls have been separated into separate front/rear systems so that if you have a fluid leak in one place, the other half of your braking system should still work.
...BUT...when I got a leak I lost my brakes entirely. I was fortunate to be able to drive off the road and not hit the car in front of me and not damage my truck, but this could have been disastrous!
I first thought that the master cylinder must have leaked internally for two reasons:
1. There was no visible fluid leak, and bleeding the brakes would pull an endless supply of air bubbles.
2. Even if it was a leak or if it was air in the lines, I SHOULD NOT have lost BOTH front and rear brakes.
The master cylinder is "supposed" to be the only place where you can loose all your brakes at once, so I replaced it and still didn't have any brakes, so I replaced it again (just to make sure I hadn't gotten a bad part) and still no brakes.
Next, I plugged all of the outlets from my proportioning valve and had a rock-solid brake pedal (ie: no master cyl internal leak)...but once I hook up the rear brake line (even with the front ports of the valve blocked OR properly hooked up) I loose ALL my brakes at once again.
Is it really possible that a VERY COMMON brake proportioning valve turns my brake system into a single point of failure?...or am I just missing something.
Thanks in advance!
Old 10-18-2010, 06:41 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I have not heard of one doing that, But i have heard of one sezing up and not allowing fluid to flow. They can go bad i don't think it happens very often though. So did you notice if the fluid was by-passing through the booster or not ?
Cole
700R4 Why are the TCI manual valve body instructions so lousy? Bayley Transmission - Rearend 24 02-16-2009 01:49 PM
proportioning valve question ScottRods2945 Suspension - Brakes - Steering 1 07-01-2007 06:52 PM
G-Body Proportioning Valve Nalehed Suspension - Brakes - Steering 1 06-12-2007 09:48 PM
Cam Help black66 Engine 3 05-12-2003 07:15 PM
Stock eliminator 78 monte Engine 5 01-02-2003 06:10 AM
