single stage - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2010, 06:08 PM
single stage
I sprayed some single stage urethane black on an small underhood piece but forgot to add the urethane activator to the single stage when I sprayed it. I have since sanded it with 800 grit, and was wondering if its possible to leave it as is and clear coat over it? IOr should I just remove all the paint and start over?
Old 06-24-2010, 10:10 PM
soory but its best to start over
Old 06-25-2010, 06:44 AM
64 is right, however if you can sand it, it is not a true urethane and must be an enamel want-a-be conversion.
So if that is the case you can leave what you have and it should be dead in a year or two without activator and will take about 6-9 months to totally cure, depending on color and outside exposure.
Either way you cannot spray a clear over it because it does not have an activator and even 10 years from now, any urethane or primer will have a 90% ++ chance of looking like you sprayed paint stripper on it.
Old 06-25-2010, 09:24 AM
Thanks Barry and 64r1, Fortunately its not a big part and wont be too much trouble to strip.
Barry, since I dont know anything about paint what's an enamel want-a-be conversion? "however if you can sand it, it is not a true urethane and must be an enamel want-a-be conversion."
Old 06-25-2010, 09:40 AM
Enamels will dry with or with out an activator, urethanes will not other then skimming and once in sun soften right up again.
Common with lower grade paints and that may or may not be the situation here.
Compressor - Single vs. Dual Stage cab Garage - Tools 28 09-06-2010 04:48 PM
Air Compressor for Automotive Painting m1helmethead Garage - Tools 34 12-26-2009 07:36 PM
Single stage and duel stage air compressor? DeathByGreaser Body - Exterior 24 10-19-2005 06:33 PM
Sanding single stage? Project87c10 Body - Exterior 6 11-05-2004 12:44 PM
bc/cc over single stage? Lay'nFrame Body - Exterior 1 06-04-2003 01:56 PM
